- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware Released RAX80 1.0.3.88
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware Released RAX80 1.0.3.88
This new firmware has been problematic on my rax80, which was generally working fine beforehand. The big problem is the need for factory resets. I had to factory reset after the firmware installation itself. Annoying, but workable. I had a power outage tonight, and when the power came back on my router was doing the same thing it was after the firmware install. I had to factory reset again. If I have to factory reset every time the power goes out, this thing is going to get thrown in the trash pretty quickly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any idea why factory reset is necessary after firmware update? Seems a bit extreme. I also have a EAX80 and an EX7700...will I need to reset the extenders as well?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It isn't always. But updates sometimes introduce changes that are not compatible with older settings.
This is also a support call of last resort when people have problems. "Do a factory reset". Sometimes it works, but often not.
You can always back up your settings before you reset. If that doesn't fix problems, you can then restore the settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Orts001 wrote:
Mine bricked itself after the upgrade from 1.0.2...
What do you mean by that?
The "bricked" term doesn't have a technical definition, but people usually lob it in when they have corrupt firmware, the flashing power LED.
When that happens you can forget about factory resets or restoring settings.
What you can try is the recovery reset:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, you may end up in a state where you can reflash the firmware, or get into TFTP:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only option to get access back is through hard reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Another "issue" I've noticed with the new firmware is that Xbox one now doesn't recognize the new WPA2(AES)/WPA3 config and does not accept the WLAN config.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a factory reset this morning...and many many hours later I have my network back up and running. I reset the router with the extenders turned off to simplify things. After the reset, the network drops started ocurring almost immediately. I tried different settings and reboots trying to narrow the problem down. Once I turned off OFDMA for 2.4 and 5GHz networks and set security back to WPA2-PSK from WPA2(AES)/WPA3 and restarted the router. Instantly, after reboot everything started working again. I added both extenders to my network and I haven't experienced any issues for several hours. The only odd thing I see now are two devices on my network that have IP addresses outside the range of addresses my router would assign. My IP's start with 10.0.0 and one of the addresses is 169.254.95.216 (which I know is connected to a Nanoleaf smart lights) and another 192.168.1.250 which I have no idea where that is from.
I''m just happy to be back up and running.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It may come from a modem/router that sits in front of your RAX80.
The RAX80 likes to use 192.168.1.1, but if it senses another router on your network it will opt for 10.0.0.1 or something else.
As various manuals say:
"If the router detects a conflict with a WAN IP address, it changes its IP address to 10.0.0.1 or 172.16.5.1."
This may well explain the problems you had, not to mention the mess of addresses that you see.
I may be well off track, but you can confirm that by telling us the make and model of the modem, of there is one, in front of your router.
If all is well now, fine, but if I am correct, and you want to avoid future problems, you might want to sort out this "double NAT" obstacle.
What is Double NAT? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the Costco RAX75, but the firmware appears to be the same as the RAX80. This is the most frustrating experience I have ever had with any piece of technology. I get constant wifi dropouts from all devices. Any devices that are hard wired work perfectly fine.
I tried factory resetting several times and nothing seems to help. Most of the time I have to turn off wifi on my device and turn it back on in order to reconnect. I need to do this every few minutes for some devices. This firmware is completely broken.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After server hours my wifi seems to have stablilzed on its own somehow. I suspect the issues were related to that new Netgrear Armor thing (which I swear I did NOT enable but it turned on anyways). I noticed hundreds of login attempts in my syslog for my server on my network. This lasted a few hours and they were originating from my router. I turned that off and won't be using it. Hopefully things stay stable - fingers crossed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear Support updated my AX8/RAX75 to the new .88 firmware because we had several malfunctions on my router with the .76 release.
After 2 hours of remote screen sharing, updating, resetting, testing, uploading screenshots and logfiles, the 2nd tier support technician had run into so many problems, that we downgraded to .64 again. Problems with the new release included total loss of admin connections from iOS devices, frequent loss of admin connection from Windows10 Pcs (both wireless and ethernet), the router not recognizing attached USB devices correctly, Readyshare folders deleted at reboot etc.
/bayarnd
- Mark as New
- Bookmark
- Subscribe
- Permalink
@bayarnd wrote:Netgear Support updated my AX8/RAX75 to the new .88 firmware because we had several malfunctions on my router with the .76 release.
/bayarnd
I spoke with a tech this weekend and explained how 1.0.1.64 has been the most stable for me. I also explained how that version of the firmware is missing from the downloads section for the RAX80. Hopefully, they get this straightened out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm using the standard AT&T router since it came from my provider but I have turned off the Wi-Fi bands and hard wired my Nighthawk to the AT&T router. i have 120+ devices on my home network an this was the easiest way to preserve the existing networrk name when I added the Nighthawk.
I don't see how those strange addressess appear as the AT&T router isn't acting as a DHCO service and passing out IP addresses on my wireless network.
I'm just glad the network is back up and running again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This release works allows home automation to work blazingly fast and the cooling fan to kick in.
Apart from reformatting USB drives to NTFS, which works perfectly, no special settings to allow it to work really well. Very happy vs previous firmware.
I did can the Armour and Circle options, enabled AX and ODFMA on both radios, WP2&WPA3.
Not being a smartass but maybe full reset and one issue at a time works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@pir4tedirk wrote:
I have (only) 27 devices on my network, 4 WiFi 6 and 7 wired.
Are you able to transfer large files (3GB or more) to the USBNetword drive?
How are you speeds compared to the last firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seriously fast network, fastest ever been on. All devices though this one router, one fast switch for entertainment hub.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
