Sep 08, 2022Guru - Experienced User
New - RAX120 / RAX120v2 Firmware Version 1.2.8.40 Released
New Features:
- Supports the XunYou gaming feature (for China only)
- Removes the gaming feature, Funjsq (was supported for China only)
Enhancements:
- Improves system stability. <Maybe a fix here for the random reboots seen on v2 units.
Security Fixes:
- Addresses security vulnerabilities.
- For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Bug Fixes:
- Fixes the issue where ACLs that exceed 128 IP addresses disappear during a firmware upgrade.
- Various minor bug fixes.
Download Links:
RAX120/120v2: Same version for both model RAX120 series routers.
https://www.netgear.com/support/product/RAX120#download
To update your router’s firmware, follow the instructions in your router’s user manual. To find your router’s user manual, visit:
https://www.netgear.com/support/product/rax120.aspx#docs
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Let us know how it works for you...
- mudboneApprentice
I have noticed that ever since I installed the new firmware my RAX120 (v1) only logs admin login attempts. Prior to the new firmware I was getting a lot of DOS Attack errors as well. I did not factory reset the router after the firmware upgrade. Why did it stop logging everything else except admin login attempts?
Have you been into the browser graphical user interface (GUI) for the router to check what the browser is set to log?
ADVANCED > Administration > Logs
Prior to the new firmware I was getting a lot of DOS Attack errors as well.It would probably be too much to ask, but perhaps Netgear has finally found a way to suppress these fake alerts.
I did not factory reset the router after the firmware upgrade.New firmware should not normally need a reset, but it is the first thing to try if you have problems with new firmware.
Backup the device's settings first, just in case it doesn't fix the problem and you want to recover the settings. But be warned that even if the reset does work, retrieving the settings may break things again.
- mudboneApprentice@michaelkenward wrote:"It would probably be too much to ask, but perhaps Netgear has finally found a way to suppress these fake alerts."I had to do a double take on that comment. Those DOS alerts are not fake and there is supposed to be a way to suppress them if you don't want to see them. All you have to do is uncheck a box.I was still not seeing the DOS messages in the log so I factory reset the router tonight and it did not fix the issue. So either the router software is no longer blocking the DOS attempts or just not logging them.I don't have time at the moment but it looks like I am going to have to go backwards on the firmware. To much stuff was broken in this version. The log needs to work properly.
Firmware update and still getting Random reboots with the RAX120 router. Factory reset and disable the wmm for 2.4 and still reboot persists.
Thanks for letting us know.
Follow on questions in that other thread.
- Definitely DID NOT fix the random crashes where it drops wifi and disconnects from the internet.
- Anonymous
pfffft, disabling the 2.4Ghz should not be a solution.
Also internet stops dropping with this "fix".... but... Netgear pls contribute more to OpenWRT....at least the community could fix this.
The community doesn't have the recourses to fix this. This is NG responsibility to fix this.
- Anonymous
Ah boy, here we go again.
After some weeks with 2.4Ghz disabled. Now the wired connection starts being dropped again intermitently and sometimes it wont be up again until i restart this RAX120.
Also there seems to be some kind of intermittent issues on 5Ghz now... amazing.
Fan always runnning, latest intel ethernet drivers, etc etc.
What do? return this unit and.... go back to the R7800? I don't think a factory reset would help honestly...
What is the first 3 characters of the routers serial number seen on the bottom sticker?
Has a factory reset been performed since you updated FW?
- mudboneApprentice
I reverted back to firmware version 1.2.3.28 from 1.2.8.40 on my RAX120 v1 router and factory reset it. The logging is now working once again the way it should have in the newer version. I do not know what the firmware developer fixed in version 1.2.8.40 but the logging issue in it was reprehensible in my opinion. I like NetGear's hardware but they need to put way more resources into their firmware development. I am a software engineer and if I had this many bugs in my code I would be fired. Maybe they should actually test their firmware with a smaller group of knowledgeable users before releasing it to the general public. Version control is another issue I have seen. They have fixed bugs in the past then later reintroduce them back into the firmware. I will upgrade to the next version when it comes out and cross my fingers.
Did you factory reset and setup from scratch after you applied v.40?
- mudboneApprentice
Yes. Both on V1.2.3.28 and V1.2.8.40 plus I manually entered all the settings for each. I do not trust backups to always restore the settings correctly. Below is a sample of all the "DoS Attack" entries I had in the log over a roughly 23 hour period. I want to see this stuff and I do not want it suppressed. Even if they are not actual DoS Attack's I can see what is scanning my router.
[DoS Attack: ACK Scan] from source: 14.191.135.46, port 17729, Wednesday, November 23, 2022 21:53:57
[DoS Attack: ACK Scan] from source: 14.191.135.46, port 17729, Wednesday, November 23, 2022 21:53:53
[DoS Attack: ACK Scan] from source: 14.191.135.46, port 17729, Wednesday, November 23, 2022 21:53:49
[DoS Attack: SYN/ACK Scan] from source: 95.217.30.172, port 443, Wednesday, November 23, 2022 21:16:09
[DoS Attack: ACK Scan] from source: 185.224.128.7, port 30569, Wednesday, November 23, 2022 20:35:42
[DoS Attack: TCP/UDP Echo] from source: 8.8.8.8, port 53, Wednesday, November 23, 2022 19:55:09
[DoS Attack: SYN/ACK Scan] from source: 5.75.245.238, port 443, Wednesday, November 23, 2022 18:54:31
[DoS Attack: SYN/ACK Scan] from source: 107.149.2.16, port 80, Wednesday, November 23, 2022 18:50:07
[DoS Attack: ACK Scan] from source: 180.248.8.52, port 53185, Wednesday, November 23, 2022 18:14:49
[DoS Attack: SYN/ACK Scan] from source: 35.214.109.143, port 443, Wednesday, November 23, 2022 17:57:01
[DoS Attack: ACK Scan] from source: 185.224.128.7, port 11213, Wednesday, November 23, 2022 17:40:37
[DoS Attack: NULL Scan] from source: 60.161.81.116, port 404, Wednesday, November 23, 2022 17:09:56
[DoS Attack: SYN/ACK Scan] from source: 5.75.245.238, port 443, Wednesday, November 23, 2022 17:02:10
[DoS Attack: SYN/ACK Scan] from source: 35.214.109.143, port 443, Wednesday, November 23, 2022 14:47:32
[DoS Attack: ACK Scan] from source: 185.224.128.7, port 3491, Wednesday, November 23, 2022 14:45:18
[DoS Attack: SYN/ACK Scan] from source: 195.208.6.1, port 53, Wednesday, November 23, 2022 14:41:22
[DoS Attack: TCP/UDP Chargen] from source: 172.105.189.111, port 30219, Wednesday, November 23, 2022 14:14:16
[DoS Attack: ACK Scan] from source: 208.85.46.22, port 443, Wednesday, November 23, 2022 13:34:14
[DoS Attack: ACK Scan] from source: 208.85.46.22, port 443, Wednesday, November 23, 2022 13:32:13
[DoS Attack: ACK Scan] from source: 208.85.46.22, port 443, Wednesday, November 23, 2022 13:31:10
[DoS Attack: ACK Scan] from source: 208.85.46.22, port 443, Wednesday, November 23, 2022 13:30:38
[DoS Attack: SYN/ACK Scan] from source: 5.75.245.238, port 443, Wednesday, November 23, 2022 13:21:49
[DoS Attack: SYN/ACK Scan] from source: 149.20.190.19, port 1972, Wednesday, November 23, 2022 12:25:15
[DoS Attack: ACK Scan] from source: 185.224.128.7, port 23427, Wednesday, November 23, 2022 11:49:32
[DoS Attack: SYN/ACK Scan] from source: 51.79.163.159, port 30120, Wednesday, November 23, 2022 11:35:50
[DoS Attack: Ascend Kill] from source: 8.8.8.8, port 53, Wednesday, November 23, 2022 11:30:44
[DoS Attack: TCP/UDP Echo] from source: 94.102.61.29, port 44918, Wednesday, November 23, 2022 10:58:33
[DoS Attack: RST Scan] from source: 103.167.159.250, port 18189, Wednesday, November 23, 2022 10:10:29
[DoS Attack: TCP/UDP Chargen] from source: 192.46.221.241, port 32356, Wednesday, November 23, 2022 09:49:04
[DoS Attack: ACK Scan] from source: 185.224.128.7, port 15171, Wednesday, November 23, 2022 08:54:28
[DoS Attack: SYN/ACK Scan] from source: 5.75.245.238, port 443, Wednesday, November 23, 2022 08:47:47
[DoS Attack: SYN/ACK Scan] from source: 91.218.213.49, port 8000, Wednesday, November 23, 2022 08:23:31
[DoS Attack: WinNuke Attack] from source: 60.30.162.22, port 59779, Wednesday, November 23, 2022 07:58:15
[DoS Attack: SYN/ACK Scan] from source: 40.113.105.173, port 443, Wednesday, November 23, 2022 07:21:15
[DoS Attack: SYN/ACK Scan] from source: 195.208.6.1, port 53, Wednesday, November 23, 2022 05:54:47
[DoS Attack: SYN/ACK Scan] from source: 35.214.109.143, port 443, Wednesday, November 23, 2022 05:47:50
[DoS Attack: SYN/ACK Scan] from source: 5.75.245.238, port 443, Wednesday, November 23, 2022 05:36:05
[DoS Attack: SYN/ACK Scan] from source: 195.208.6.1, port 53, Wednesday, November 23, 2022 04:52:43
[DoS Attack: SYN/ACK Scan] from source: 88.198.21.103, port 29825, Wednesday, November 23, 2022 03:58:15
[DoS Attack: SYN/ACK Scan] from source: 35.214.109.143, port 443, Wednesday, November 23, 2022 03:01:35
[DoS Attack: SYN/ACK Scan] from source: 40.77.45.24, port 30208, Wednesday, November 23, 2022 02:49:36
[DoS Attack: SYN/ACK Scan] from source: 195.208.6.1, port 53, Wednesday, November 23, 2022 01:27:26
[DoS Attack: ACK Scan] from source: 162.247.241.14, port 443, Wednesday, November 23, 2022 01:10:14
[DoS Attack: ACK Scan] from source: 162.247.241.14, port 443, Wednesday, November 23, 2022 01:09:59
[DoS Attack: ACK Scan] from source: 162.247.241.14, port 443, Wednesday, November 23, 2022 01:09:43
[DoS Attack: ACK Scan] from source: 162.247.241.14, port 443, Wednesday, November 23, 2022 01:09:28
[DoS Attack: ACK Scan] from source: 162.247.241.14, port 443, Wednesday, November 23, 2022 01:09:13
[DoS Attack: ACK Scan] from source: 162.247.241.14, port 443, Wednesday, November 23, 2022 01:08:57
[DoS Attack: ACK Scan] from source: 162.247.241.14, port 443, Wednesday, November 23, 2022 01:08:42
[DoS Attack: SYN/ACK Scan] from source: 51.81.82.90, port 22, Wednesday, November 23, 2022 00:50:57
[DoS Attack: SYN/ACK Scan] from source: 51.81.82.90, port 22, Wednesday, November 23, 2022 00:50:47
[DoS Attack: SYN/ACK Scan] from source: 45.95.55.236, port 80, Wednesday, November 23, 2022 00:39:39
[DoS Attack: SYN/ACK Scan] from source: 35.214.109.143, port 443, Wednesday, November 23, 2022 00:04:07
[DoS Attack: SYN/ACK Scan] from source: 35.214.109.143, port 443, Wednesday, November 23, 2022 00:04:06
[DoS Attack: ACK Scan] from source: 8.240.217.254, port 80, Tuesday, November 22, 2022 23:43:54
[DoS Attack: ACK Scan] from source: 8.240.217.254, port 80, Tuesday, November 22, 2022 23:43:24
[DoS Attack: ACK Scan] from source: 199.187.116.122, port 30106, Tuesday, November 22, 2022 23:20:39
- elkendAspirant
I’d like to test the beta that keeps the RAX120v2 up and running. First three SN digits are 6JY. Thank you!
- LocustfogAspirant
Is there a new beta firmware? My serial starts with 6JY. About 9 months ago I gave up on it completely and put it away in a closet, waiting for the day this investment is fixed in firmware. I am approaching the 1 year anniversary since I purchased this nightmare and I decided to take a peek at the forum. I set up the unit from factory reset today and I have had no issues on v40 so far. If there is a beta that fixes this once and for all, how do I get it?
- blakey84Guide
Yes there is, best to request it on this thread though if you haven't already
Solved: RAX120 V2 Constant Random Reboots - Page 25 - NETGEAR Communities
- ssssssTutor
Where I can download v2 beta firmware? The other thread is locked and unable to reply anymore. thanks,
- jsspamAspirant
can someone send me the beta firmware? my router keeps randomly rebooting during work hours. Getting very frustrated
#6JY21
comcast
netgear cm600
- AliCat6935AspirantI’ve done everything I can think followed every fix and still rebooting randomly could anyone provide the beta firmware to fix this stupid issue 😭😭
