- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New - RAX20/38v2 Firmware Version 1.0.11.112 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bug Fixes
- Fixes the issue where Advanced Tab cannot function when using Safari Browser.
- Fixes the issue where QoS priority setting cannot be saved after enable QoS.
- Fixes the issue where DHCP reservation cannot support maximum 253 IP addresses.
- Fixes minor bugs.
Firmware Update Instructions
Download Link:
RAX20:
https://www.netgear.com/support/product/rax20.aspx#download
RAX38v2 only:
https://www.netgear.com/support/product/RAX38v2#download
RAX38v1 is not compatible.
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RAX20.aspx#docs.
https://www.netgear.com/support/product/RAX38v2.aspx#docs.
Manually update router FW:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: A factory reset and setup from scratch maybe needed if problems are encountered after applying FW updates:
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
This article applies to:
Wireless AX Router Nighthawk (WiFi 6) (1)
Let us know how it works for you in this thread...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RAX20 Firmware Version 1.0.11.112 Released
It may not be posted up on NG auto update services yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RAX20/38v2 Firmware Version 1.0.11.112 Released
I forgot to follow up my post a few days ago to say that the Firmware is now showing and it installed ok.
The CPU info is now working in this firmware so i now have nothing to moan about.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
