× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
New - RAX45 Firmware Version 1.0.5.106 Released
Guru
Enhancements:
Includes enhancements for checking the device password strength
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Bug Fixes:
  • Fixes the issue where the 2.4 GHz guest WiFi cannot be enabled using the Nighthawk app for iOS.
  • Fixes the issue where the Wireless and Guest WiFi status can only display the 2.4 GHz SSID.
  • Fixes the issue where after changing the guest network SSID, the previous SSID settings display.
  • Fixes minor bugs.
Firmware Update Instructions:
Download Link: https://kb.netgear.com/000064501/RAX45-Firmware-Version-1-0-5-106
To update your router’s firmware, follow the instructions in your router’s user manual. To find your router’s user manual, visit https://www.netgear.com/support/product/RAX45.aspx#docs.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
This article applies to:
  • Wireless AX Router Nighthawk (WiFi 6)
Message 1 of 5
mrgncann
Re: New - RAX45 Firmware Version 1.0.5.106 Released
I am trying to use the Nighthawk app to update the firmware on my RAX45 router.   I am using the Check for updates function and it errors saying a problem has occur checking for updates.    our firmware is currently V1.0.2.82.   Any ideas?
Message 2 of 5
Guru
I recommend using a wired PC and web browser to apply FW updates:
Message 3 of 5
SLMinLB
I am having the same issue. I have to wonder why the app offers to check for firmware updates if the process doesn’t work.
Message 4 of 5
Guru
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2257 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
