- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New - RAX70 Firmware Version 1.0.12.114 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
New Features: 05/04/2022
- Supports the XunYou gaming feature (for China only)
- Supports Hong Kong PCCW IPTV requirements
- Removes the gaming feature, Funjsq (was supported for China only)
Security Fixes:
- Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Firmware Update Instructions:
Download Link: https://www.netgear.com/support/product/rax70.aspx#download
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/RAX70.aspx#docs
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: A factory reset and setup from scratch maybe needed if problems are encountered after applying FW updates:
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Wireless AX Router Nighthawk (WiFi 6)
Let us know how it works for you...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - RAX70 Firmware Version 1.0.12.114 Released
New FW available:
Good Luck.
