× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk 5400
Ksnyder
Nighthawk 5400
Replaced a linksys router with a 5400 and can’t get Dell laptop to see either band as an option. Kept name and password the same as linksys. Everything else in the house connected fine.
Message 1 of 10
Accepted Solutions
Guru
Re: Nighthawk 5400
@Coop102072 wrote:
Would be helpful if you shared what he unchecked as I am having the same issue with my Lenovo and Hp laptops....every other device is fine.
Thanks
I have a feeling he unchecked "enable ax".
many laptops with intel chips have issues. Reason why is people rely on the manufacturer (lenovo/hp) or windows update to update the drivers. And they don't.
If you go to the chip manufacturer website of your wireless card, many times theres newer drivers that have fixed many issues with AX devices.
Message 6 of 10
All Replies
Guru
Re: Nighthawk 5400
5400 isn't a model
What model did you buy?
Does this dell laptop have an intel wireless chip in it?
if so, get the driver directly from Intel and not through dell or windows updates. both are far behind and struggling with the newer AX devices. Not sure if you're new router is an AX router as you didn't put the model.
Message 2 of 10
Ksnyder
Re: Nighthawk 5400
Nighthawk AX6 6-Stream AX5400 WiFi Router(RAX50S)
Message 3 of 10
Ksnyder
Re: Nighthawk 5400
My younger brother (IT guru) came over and logged into the router webpage and there was a setting box checked (not sure which one) but he had never seen it before, unchecked it and was able to connect without any problem after that.
Thanks for any/all of your time!!
Kraig
Message 4 of 10
Coop102072
Re: Nighthawk 5400
Thanks
Message 5 of 10
Guru
Re: Nighthawk 5400
Thanks
Message 6 of 10
Coop102072
Re: Nighthawk 5400
Thanks!  I started fiddling around before your answer and yes, that did the trick.  Thanks so much.
Message 7 of 10
Ksnyder
Re: Nighthawk 5400
Ya.........sorry........I was at work and my wife said, "I don't know, he just unchecked something and it worked"!!
I hadn't had a chance to reach out to him.....
Glad we are both up and running!
K
Message 8 of 10
Guru
Re: Nighthawk 5400
Just an FYI, it does disable wireless AX.
I'd try updating the wireless chip driver in those computers. And then try re-enabling wireless AX.
if it works, great! If it doesn't,  you can always uncheck it until the manufacturer updates the wireless driver.
Message 9 of 10
Coop102072
Re: Nighthawk 5400
I know... kind of defeats the purpose of getting this router. I did update the Lenovo and will try at end of day, but can't do the HP as that is a work computer and I need the firm to push the update. I'm happy to toggle the button for now.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2804 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
