×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk 6700v3 not achieving GB speeds
Styger
Follower
As the title suggests - just upgraded to a Gigabit internet package, and began to run some tests this morning. On the wifi analytics app, I was able to achieve 866 Mbps around the apartment, which is great. However, I ran some tests on my wifi enabled desktop (MSI x570 Tomahawk Wifi motherboard), and I'm only achieving 180-200 Mbps.
Went into QoS and WMM is enabled, so unsure as to what's causing such a staggering difference in performance.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Guru
Re: Nighthawk 6700v3 not achieving GB speeds
A couple things.
1. the R6700 isn't going to hit gigabit speeds over wifi. There's a lot of misunderstanding about wifi speeds and what is capable.
i'd take a read through this artilce for more info on realistic expectations on wifi. Understand Wi-Fi 4/5/6/6E (802.11 n/ac/ax) (duckware.com)
2. that 866mbps that you're getting? I'm betting thats link speed and not actual throughput speed.
3. depending on what wifi chip you have in your motherboard 180-200mbps might be pretty good. tough to know without more info on what wireless card is in there.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 410 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
