× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk AX1800 Constantly pinging www.netgear.com
Chainsaw801
I just bout the AX1800 form Costco.  I run a Pi-Hole ad blocker and I was bummed when I saw you couldn't add custom DNS servers to the DHCP server.  After doing some digging I found that I could point the DNS server from the Internet Setup page to my Pi-Hole ad blocker.   It works okay and does block the ads however all traffic shows that it's comeing from _gateway and doesn't seperate all the traffic to the other clients on the network.   After two days,  "_gateway" had reached the top of the Permitted Domains with a very high rate going to www.netgear.com.    (I'm NOT pinging www.netgear.com on any machine)  When I pulled up the logs it does look like it's a constant ping coming from the main router. The time stams are showing around two per second.    Is this normal?   If not,  how do I shut this off?    Thanks!
Message 1 of 3
Kaherdin
Guide
Re: Nighthawk AX1800 Constantly pinging www.netgear.com
I have a MR60 (MR60 router unit with a MR60 satellite).
I have been using PiHole on a Raspberry Pi Zero for a couple of months now, and since approx 2021-02-12 something, most likely my router or satellite is connecting to "www.netgear.com".
It's not the NTP, I changed that to Google's.
What the heck is going on Netgear?!
Message 2 of 3
Christian_R
NETGEAR Employee Retired
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1035 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
