- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AX4 AX3000 WiFi constantly going OFFLINE
- Mark as New
- Bookmark
- Subscribe
- Permalink
PURCHASE: March 2020
HARDWARE: Nighthawk AX4 AX3000 (RAX35)
FIRMWARE: V1.0.3.80_1.0.1
MODEM: Comcast/Xfinity in bridge-mode
NOTE: Ethernet connected devices will sometimes maintain internet access after the WiFi goes out.
This router is constantly (5+ times/day) going offline and requiring a reboot (power off/on) to get back online and functioning. There are NO new firmware updates. I've done a reset of the device, but the performance is the same.
Any suggestions on diagnosing the problem and/or a resolultion would be appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AX4 AX3000 WiFi constantly going OFFLINE
When the wifi "goes out" does it say "connected, no internet". Does it not connect at all even though it can see its broadcasting? does it not see the router broadcasting at all?
You've had this for a while, did this just start?
have you tried a factory reset and reinstall? there's been quite a few firmware changes on the AX devices and they've responded well to factory resets and reinstalls.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I actually saw all the "factory reset and rollback to earlier versions" posts, but thought I would try a set of config changes that someone posted as a solution - Set the following to OFF: "AX Mode", "QoS", "Beanforming" and "Airtime fairness". Needless to say, these did not work.
I then did the factory reset and reverted to the prior Firmware Version - V1.0.3.64_1.0.1. Note, I chose this version even though it said it was for the RAX40 and mine is a RAX35 (I haven't been able to find any informaiton on the difference between these two "models"). After 24 hours, I've not had the WiFi stop working nor have I needed to reboot the WiFi.
I appreciate your response. -Kyle
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same issue. My 12 year old router never dropped the internet. My iphone 11 keeps saying poor internet connection, while showing me the dreaded circle of death. Streaming TV just turns off. I was ready to return this thing and plug the old one back in. Thought I'd come on here to see reviews. All I'm seeing for a fix is a factory reset and do not update firmware? Ready to return it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@sidelined wrote:I'm having the same issue. My 12 year old router never dropped the internet. My iphone 11 keeps saying poor internet connection, while showing me the dreaded circle of death. Streaming TV just turns off. I was ready to return this thing and plug the old one back in. Thought I'd come on here to see reviews. All I'm seeing for a fix is a factory reset and do not update firmware? Ready to return it.
If you've got the ability to return it, do it.. It's not worth your time going through these hoops and hurdles to try and get it working properly when the underlying fault needs to be fixed by Netgear. The only reason why some of us (like myself) have just been pestering Netgear on and on to push them to get a fix out, is because we cannot return it. If I knew I'd run into all these issues from the start, I would have purchased a router from ASUS instead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Per my post above, I did the factory reset (make sure you hold the reset button for 30-60 seconds) and then reverted to an earlier firmware and it’s been working perfectly since.
BAD FIRMWARE: V1.0.3.80_1.0.1
GOOD FIRMWARE: V1.0.3.64_1.0.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KT62 wrote:
Factory Reset + Earlier Firmware = FIX
No, that is not a fix.. that is a workaround.. A fix is when Netgear actually correct the issues with the firmware that was released (v x.80) as there were new features added as well as other tweaks in that version. They should also remove the .80 firmware version from the website/server as people unaware of said issues, will be downloading it or updating to it not knowing that they're in for the worst ride of their lives...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Eagle-Two wrote:After downgrading to 1.0.3.62 on my RAX35 and disabling AX, I've been up for 14 days. When I was using 1.0.3.80 I had frequent lockups and disconnects.
yes this is the only workaround for now, until Netgear finally release an updated firmware. On the beta firmware I have not needed to disable AX and it has been working fine for the most part. Hopefully Netgear can hurry the hell up and release the updated firmware for RAX35 and RAX40 to all users. It's been months and months now of issues after issues yet they still have not done anything about it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been reading here and in other posts and it seems like the old firmwear version is the way to go. I can not figure out how to access or download it. Would anyone have a link or can you direct me to a source?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.netgear.com/support/product/RAX40.aspx
click downloads.
Then "view previous versions"
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK after weeks and numerous follow ups to my L2 support representative, they finally have another beta for me to test.. RAX40-V1.0.3.83_1.0.10 dated 4th November 2020
I'll be testing and monitoring over the course of the week and will report back my findings and experience with the update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KT62 wrote:
@itsmehuey, I’m curious what your results have been with the latest firmware version. When you have time, can you post to this thread. Thank you. -Kyle
Mentioned a couple of times in other threads regarding the same issue, but will mention here too -
first beta was OK however I did run into 1 initial wifi drop about 10 minutes after installing.
second beta (currently on) has been rock solid for the last month with no drops whatsoever. performance has been good - tested with 3 WIFI6 devices and speeds are great. Both 2.4 and 5Ghz bands working and I've not had to disable anything in my settings.
One thing that I haven't been able to get working though is my new 14TB Western Digital external HDD plugged in through USB. ReadyDLNA works as a media server to stream between network devices/TV/phones/iPads, but I'm unable to get ReadyShare SMB working - ReadyShare shows as "Ready" but you can't see the USB storage device. Not sure if that's an issue with the firmware or just a limitation of ReadyShare. My 4TB Western Digital external SSD worked fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@itsmehuey, I really appreciate the timely response. Are they giving you any indications on when they will GA that version? -Kyle
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KT62 wrote:@itsmehuey, I really appreciate the timely response. Are they giving you any indications on when they will GA that version? -Kyle
No problem.
And no, they have not mentioned anything and are likely not to mention anything at all. Who knows when a public release will be available. Netgear have been rather terrible with this device.
