×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk AX4 AX3000 goes offline after about a month of use
ScottW61
Follower
I returned the first ax3000 and replaced it with a new one. Did the set up internet works for about a month then goes out. All lights are green but no connection. Luckily I have kept my old netgear g54 so I can at least have access. Is this unit just junk or do I need a degree in electronics to keep it working? I have no router knowledge at all. Anyone else have this kind of issue? If so is there a fix that I can do?
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Nighthawk AX4 AX3000 goes offline after about a month of use
Hello ScottW61,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 478 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
