× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk AX4 refuses Nokia 9 after Android 10 update
hmobius
My Nokia 9 got updated to Android 10 yesterday but after restarting, it would not connect to my Netgear Nighthawk RAX40 Wi-Fi router on either 5GHz or 2.4GHz network. All other devices in my household connected to wifi fine. When i go to work, the phone connects to the work wifi fine.
So I'm guessing this is an issue between Android
10.0 and the Netgear Nighthawk RAX40.
Following another thread on this forum, I tried downgrading the security level on my 5G network from "WPA2-PSK (AES)" encryption, to "WPA-PSK (TKIP) + WPA2-PSK (AES)" and the phone connected straight away. I don't know if this is a bug in Android 10 or the AX4 but I'm logging this here for reference and hoping that a security fix is issued quickly. I have logged this as a bg with Nokia but don't know where to log it with Google or Netgear.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 8
Guru
Re: Nighthawk AX4 refuses Nokia 9 after Android 10 update
Try disabling AX and rebooting the router.
It wouldn't be the first device that had issues with AX and with it getting a new update, maybe there's bugs in it.
Message 2 of 8
hmobius
Tried that - didn't work.
Message 3 of 8
Guru
Will it connection if you disable security on the wireless? Its not a good option but just for testing purposes.
Message 4 of 8
hmobius
You mean disable it completely rather than just downgrade it as i have done?
Message 5 of 8
Guru
Just temporarily, disable it to see if it's and outside with wifi protection
Message 6 of 8
hmobius
OK - tried that.
Phone connected to router no problem when acting as an open router.
Message 7 of 8
Guru
that usually points to a bug with the nokia upgrade. Especially since it worked before the upgrade.
running an open network is usually not the best idea. You could setup the guest network as open so at least it has some network isolation.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1320 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
