×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk AX5 RAX30 and Optus Ultra WiFi Booster
amona121
Follower
I've just changed from Optus to Dodo and I have kept the Optus Ultra WiFi Booster. I want to install linux on a late 2014 Mac mini but linux doesn't have the required drivers for wireless access. I don't have access to ethernet as its in another section of my house. That's why I need to get the wifi booster working so I can plug an ethernet cable in and access the web. It worked great with Optus modem. Is there some settings I can use to enable the Nighthawk AX5 RAX30 to connect with the Optus Ultra WiFi Booster? I don't really want to buy another booster/extender if I can get away with the Optus one? I've tried the reset etc but no luck. Any help greatly appreceated.
Message 1 of 5
julunyeti
Message 2 of 5
Re: Nighthawk AX5 RAX30 and Optus Ultra WiFi Booster
If your problem is with the Optus Ultra WiFi Booster. I'd start at that end. Netgear can't help you with that.
It might help if you told people what the rest of the network looks like. What is the modem/gateway/ONT that connects you to the Internet?
What is the layout of your network:
Modem >>> RAX30 >>> Optus?
How are you connecting the RAX30 to the Optus? Wired or wifi?
Have you looked in the manual for details on "bridge mode"?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual
Enable bridge mode
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 5
Guru
Like @michaelkenward says, the optus is the issue. Its designed to only work with the optus modem/router. Just like how Netgear's orbi satellites (for the most part) only work with orbi routers.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 4 of 5
If that is the case, if @julunyeti still has the Optus modem, would it work to use that as an access point as a link to the extender?
But that takes us back to the original point, it ain't down to Netgear's router to work with an Optus device.  Go ask them for help in how to get their hardware to work with the Netgear router.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 399 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
