×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk AX5400 router
Naloe77
Follower
Good afternoon- I upgraded to a nighthawk AX5400 wifi6 router. I am looking for help for 2 issues.
1) since I hooked this up, my LG TV keeps asking for a pairing key (it looks like for a phone) remote/TV/cable/netflix etc. all work properly.....how do I stop this prompt? or what is it asking me to set-up?
2 On the router itself - the internet LED is red (2nd light from the top)...internet access seems to be working fine for laptops/phones etc.
Thank you in advance!
Message 1 of 3
CrimpOn
Guru
Re: Nighthawk AX5400 router
There are a lot of Netgear products that marketing has labeled "AX5400" by adding together some imaginary communication speeds.  Please report the product number that appears on the Product Label on the bottom of the case.
With WiFi connection working correctly, your hunch is almost certainly correct.  The TV is trying to pair with a smartphone, perhaps for "casting" to the TV from the phone. If you provide the LG model number, we can look in the TV user manual to see what is going on.
I love my Orbi.
Message 2 of 3
Guru
on #2, if the internet led is red, it usually indicates either a successful connection to the gateway but not a IP address or a 10/100mbps connection and not gigabit. tough to know without knowing what your gateway is.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 425 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
