× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk AX6 6-Stream AX5300 WiFi Router
Beckyj636
I have the AX 5300, With Charter Internet. The Internet is pushing at one gig From Charter, but the router goes consistently from 950 mbps to 500 mbps. ish.. Up and down like a yo-yo. If anyone has any ideas please advise.
Newcat 5 cables
The router is only two years old. But out of warranty. I would really hate to have to go buy a brand new one.
Message 1 of 13
Guru
Re: Nighthawk AX6 6-Stream AX5300 WiFi Router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are you speed testing with a wired PC or wireless device? Wired speed testing is preferred with a PC or laptop.
Message 2 of 13
Beckyj636
Firmware version V1.1.4.28
All I know is Charter said that’s the newest modem they have (they replaced it a year ago ) and when I tested the speed from the computer directly from the modem, it was 960 mbps. And yes, after I double checked my receipts on those cables, they Cat 6.
This router is about a year and a half old.
This problem just started like three days ago ago.
Message 3 of 13
Guru
IF you can get a model# off the ISP modem, would be helpful.
This happen across multiple connected PCs or Laptops?
Possible if this had been working for a while, something on your devices may have changed?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 4 of 13
Beckyj636
Model number is ET2251
And all those features that you had suggested are in have been disabled
Message 5 of 13
Kitsap
Master
For consistency, recommend you use the Ookla stand alone testing application available from the play stores.  Install the program on a computer and connect the computer to your router with an Ethernet cable.
This test setup avoids any of the inconsistencies associated with testing through a web browser or over Wi-Fi.  The Ookla program also keeps a good historical record of the results.
Even with the Ookla application, real world test results can vary by plus or minus 15 Mbps from test to test.
Have you tried the internal throughput test option available in the Nighthawk mobile application?
Message 6 of 13
Beckyj636
I did here is the last set of results.
Message 7 of 13
Beckyj636
Do you know of any self diagnostics you can do on these nighthawk routers?
Message 8 of 13
Kitsap
Master
No, not that I am aware of.
Message 9 of 13
Guru
Message 10 of 13
Beckyj636
Those results were the ones that came from the router that is hardwired. And it’s using the same site as you suggested. So those are not Wi-Fi.
Message 11 of 13
Guru
The one attachment shows it being wireless.
What wired device are you using for speed testing?
Using Ooklas installable speed test on this one wired device? PC or laptop should see near 1Gb if you have this service with the ISP.
What speeds do you get with a wired PC connected directly to the back of the ISP modem?
Message 12 of 13
Beckyj636
Those were the results that I took from the Nighthawk app. When I ran the test, it was not getting run from my phone. It was getting run from the Nighthawk router itself.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 1579 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
