×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk AX6 AX5400 and existing bulk cat6a not working
scotmicharm
Follower
Just upgraded from Nighthawk R7000 where existing bulk cat6a cable in the home works. The new Nighthawk AX6 AX5400 is not working with this existing cat6a cable. I tried some retail cat6a cable with the AX6 and it was successful. Thoughts on how to diagnose?
Message 1 of 2
Guru
Re: Nighthawk AX6 AX5400 and existing bulk cat6a not working
You kind of already did the diagnosis.
You found one set of cable run didn't work but replacing it with a new/premade did work.
Kind of points at the cable. You can try replacing the ends on the cable to see if there's a bad pair or miswiring going on.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 359 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
