Orbi WiFi 7 RBE973
Reply
Nighthawk AX8 DHCP Option 61 support
KGT94
Follower
Hi. My ISP in the UK (SKY Fibre) requires DHCP Option 61 authentication support to log into the WAN via a VDSL modem. Sky doesn't support PPPoE or regular DHCP.
The R9000/X10 supports this as of v10.0.4.12. Before I buy an AX8/RAX80, does anyone know if it supports this, or can check? Thanks.
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Nighthawk AX8 DHCP Option 61 support
You can find the user manual below you can find out the settings here.
http://www.downloads.netgear.com/files/GDC/RAX80/RAX80_UM_EN.pdf
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4360 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
