Mrz1125
Jul 09, 2021Initiate
Nighthawk AX8 no ethernet cable plugged into router
Just got this router and I cannot get it to connect to internet. Keeps telling me that there no ethernet cable detected. I tried switching cables and restarting modem. I can get it to connect if I use my old router. Also if I use old router and bridge it to the new one then I do get an internet connection on the new one. Just can’t get it to connect straight from modem. (Modem is an Arris SBG6700-AC)
The SBG6700 is a modem/router combo device.
it causes a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
You can go intot he SBG6700 and put it in modem only mode (think its bridge mode on that device)
Enable that, reboot the sbg6700 and then try setting up the netgear.
