- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk AXE11000 Tri-Band WiFi 6E Router Model RAXE500 (CM2000 or CM1200 or other)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello.
Sorry if this has been answered before but I can;t find it on your website or in the FAQ's
My ISP is Xfinity. I am using ARRIS cable modem/router combo and all works ok.
I want to upgrade to fastest WiFi and invest in 6E now for the future. I would like to buy Nighthawk AXE11000 Tri-Band WiFi 6E Router Model RAXE500 and will need
cable modem.
Both DOCSIS 3.1 Cable Modem (CM2000) & DOCSIS® 3.1 Cable Modem (CM1200) are supported by Xfinity.
Which of the 2 would be best fit for the Nighthawk AXE11000 Tri-Band WiFi 6E Router Model RAXE500?
Or is there a beter fit cable modem here rather than these 2?
Any other relevant thoughts here?
Thank you:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk AXE11000 Tri-Band WiFi 6E Router Model RAXE500 (CM2000 or CM1200 or other)
If the RAX has a 2.5Gb WAN Port, then the CM2000 would be a better fit as it also has a 2.5Gb WAN port. The CM1000 thru 1200 series only have 1000Mpbs ports. Though the 1200 supports LAG were the CM2000 does not as it only has 1 port.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Routerand RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks...will do....
