× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk Armor security- Nighthawk RAX120
w4wws
Since I purchased the Armor security for my router it has locked out a device on my newtork. The device is a PI-STAR which i use for ham radio, so how can i get it unblocked to i can use the PI-Star on the WWW.
Thanks, Steve
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 4
Re: Nighthawk Armor security- Nighthawk RAX120
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might do better to try there.
Message 2 of 4
Christian_R
NETGEAR Employee Retired
Hi w4wws,
Can you confirm that when you disable Armor you're able to access your device?
https://kb.netgear.com/000060900/How-do-I-turn-NETGEAR-Armor-on-or-off-using-the-Nighthawk-or-Orbi-a...
Christian
Message 3 of 4
w4wws
No it still seems that it will not get to the world wide web. it worked before the armor was put on.
Message 4 of 4
Discussion stats
  • 3 replies
  • 750 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
