× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk RAX 50 have to reboot several times a week
Retired_Member
Not applicable
Several times a week I have to reboot my router.  All the lights show it is woking, however; I won't have internet.  A few days ago it seemed to do a factory reboot by itself and I had to repogram all my connected devices (smart connect was on, but still had to enter passwords).
Message 1 of 25
Accepted Solutions
Dan32
Apprentice
Re: Nighthawk RAX 50 have to reboot several times a week
Try a PC using ethernet cable attached to one of the 4 LAN ports.  Although, if that works, it just confirms wireless has a problem.
At any rate, best to just return it and exchange it for another for the least hassle.
My 1st RAX50 was similar, I did return it for a refund (BB)  and just bought another RAX50 a month later (at an even better sale price), just to be sure it came from a different batch.  it's been up non-stop with heavy usage from a wide range of various devices for 3 or more months now.
Message 24 of 25
All Replies
Guru
What modem/gateway do you have?
What firmware is on the router?
is it only wireless devices or do wired devices drop as well?
Message 2 of 25
Retired_Member
Not applicable
Fiber modem provided by Aerux broadband
v1.0.2.72
No internet at all (wired or wireless)
Message 3 of 25
Guru
@Retired_Member wrote:
Fiber modem provided by Aerux broadband---which modem/gateway model is it?
Message 4 of 25
Retired_Member
Not applicable
I have no idea.  It's a little white box that says Aerux on it
Message 5 of 25
Guru
any numbers/model on it at all?
Trying to determine if it has its own integrated router as well
Message 6 of 25
Retired_Member
Not applicable
Alrighty, had to pry the cover off, but here is what I have:
UFiber loco   M/N: UF-LOCO
Message 7 of 25
Guru
does it look like this:
UFiber loco GPON CPE – Ubiquiti Inc.
Message 8 of 25
Retired_Member
Not applicable
attached is a pic
Message 9 of 25
Retired_Member
Not applicable
sorry, didn't realize that was a link.  Yes, exactly like that
Message 10 of 25
Guru
When it drops does it say "connected, no internet" ?
Or how exactly does it drop?
Do the led's go out?
Message 11 of 25
Retired_Member
Not applicable
Correct, connected no internet.  And, all the lights show it is working on the router.
Message 12 of 25
Guru
When its saying "connected, no internet", are you still able to access the router gui and ping the gateway or access the gateway?
Message 13 of 25
Retired_Member
Not applicable
No, I cannot access via nighthawk app. I can see connected devices with "connect anywhere" but it shows it as offline.
Message 14 of 25
Guru
go through the browser and not using the app to test that option.
Message 15 of 25
Retired_Member
Not applicable
I'll give it a whirl next time it drops
Message 16 of 25
Retired_Member
Not applicable
actually, I did try that earlier this week while I was out of town.  I could not connect, don't remember exactly what it showed/said
Message 17 of 25
Guru
Not while you're out of town. while you're home on your network. we're trying to see if the router is still talking to the gateway when it goes offline
Message 18 of 25
Retired_Member
Not applicable
I can't be on my network if the internet is down.  I have to use my cellphone to connect to browser.
Message 19 of 25
Guru
You said it shows "connected, no internet". this implies the router is working.
The next time it goes down, use a pc/laptop for connection to the router. See if you can access its gui through the browser. If you can, then try to access the gateway through the browser. the link I posted earlier with your ont info has a manual on accessing it.
Again, I understand its offline. But we're trying to determine what device is going off line.
Message 20 of 25
Retired_Member
Not applicable
ok
Message 21 of 25
Retired_Member
Not applicable
I'm not sure I understand your instructions.  If it is down, my pc will not connect to anything.  All I can see is what is on my desktop.  If I try to go out to the web, I get the dinasaur picture that says no internet.  I can use my cell phone to access a browser.
Message 22 of 25
Retired_Member
Not applicable
So, it just went down again. I could not connect to anything. Part of it could be I still really don't understand your last instructions. I typed in the IP address for both the Gateway and for the router it will not connect to anyting.
I am not sure if Netgear people check Community messages. But, this is piss poor. The router is still under warranty but they want me to pay for support. This tells me they don't really back up their products. At this point I have spent hours on this problem. I will not spend any more I will return it get my money back and buy a different router from a different company
Message 23 of 25
Dan32
Apprentice
Message 24 of 25
Retired_Member
Not applicable
Thanks for all your help
Message 25 of 25
Discussion stats
  • 24 replies
  • 3133 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
