× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk RAX12 speed issues
kelmar1228
Follower
I'm having trouble getting anywhere near the speeds I could be getting?
I have recently upgraded our NBN connection to a 250/25 plan.
Doing a speed test on the  Netgear Nighthawk app I am getting results around 240mbps so I assume that is the speed I should expect????
Here is where the problem starts.......I am getting nowhere near these type of speeds.
On my PC connected by ethernet cable I am getting maximum results around 10.78mbps (download).
WiFi speed tests on laptops, mobile phones and tablets are coming in at around 90mbps.
These results are only slightly higher than when I was on the previous 100/25 plan.
I also have 2 wireless access points in the house so the WiFi signal is excellent throughout the whole house.
Do I need to reconfigure any router settings to obtain better speeds?
Do I need to reconfigure any settings on the PC?
I would assume that the ethernet connection speed should be better than the WiFi speeds...Is this correct.
Any advice would be greatly appreciated.
Thanks
Message 1 of 3
Guru
Re: Nighthawk RAX12 speed issues
What modem/gateway is the router connected to?
After upgrading the speeds, did you try a factory reset and reinstall of the router? Could be an old qos setting causing issues.
During the reinstall, leave qos, access control, parental controls, and traffic monitoring all disabled.
Message 2 of 3
The PC is capable of gigabit and you have the required cables?
Message 3 of 3
Discussion stats
  • 2 replies
  • 516 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
