- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk RAX120 Firmware Version 1.0.1.86
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bug Fixes:
- Throughput issues occurred with Samsung Galaxy S10 (with WiFi 6) devices.
- The web interface incorrectly showed the register/unregister information after setting the ReadyCLOUD feature.
- The router reset to its factory default settings due to the NAND flash bad block issue.
https://kb.netgear.com/000061013/RAX120-Firmware-Version-1-0-1-86
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk RAX120 Firmware Version 1.0.1.86
Amazon Fire TV[NOT STICK] not seeing 5ghz SSID when DFS Channel engaged!!!
Router range are greatly reduced from AC Router[Tried all FW]
No WiFi dropping so far
Still 1971 UI
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Redtulips7 wrote:Amazon Fire TV[NOT STICK] not seeing 5ghz SSID when DFS Channel engaged!!!
Assuming you are located in the US, so FCC is applicable: As per the FCC S59-4891 applicable to the Amazon Fire TV (CL1130):
The range 5180.0...5240.0 MHz (Ch. 36..48) and 5745.0...5825.0 MHz (CH. 149...161) do indeed cover ZERO DFS channels - I fear you dig at the wrong construction zone.
FMI: https://www.amazonforum.com/forums/devices/fire-tv/466853-fire-stick-cant-find-5g-wifi an Amazon staff meber wrote (back in 2017 - so this might have changed for some models since....): "At this time, Fire TV and other Fire TV devices do not support 5Ghz DFS (Dynamic Frequency Selection) Wi-Fi bands. ..."
As per the above, lack of a FCC permissive change for the Amazon Fire TV box, ... no change.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I am in USA, probably newer upcoming Model will support then????
- Mark as New
- Bookmark
- Subscribe
- Permalink
Basically you will see differences in different environments due to the antenna layout differences, one might perform better than the other in certain home layouts and locations. If it’s a stark difference then maybe you just got a lemon.
As for range I’m not sure what you mean by that? Are you measuring the RSSI/dBM or real world throughput. And if so with what devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Note that HT160 is more susceptible to interference and AX uses 1024 QAM which makes it even more sensitive to noise so AX clients might drop to AC level link rates at mid/long range depending on your home layout and construction materials. Just use HT80 on AX and see if that helps, HT160 is nice for benchmarks but HT80 is better for stability especially when using non-DFS channels. I’m on HT160 but I there aren’t many 5Ghz APs in my area so it’s not a hassle as the ones that do exist are too far to have a noticeable impact.
Lastly try disabling MU-MIMO to see if that helps as some Broadcom based clients have issues with it on.
