× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Nighthawk RAX120v2 intermittently dropping internet on macbook
jasminabasurita
I recently purchased a RAX120. Setup was straight forward and pretty much everything has worked perfectly. The one issue I've been running into is that a macbook in my network keeps losing internet connection. The computer continues to say that it's connected to the router, but the router doesn't show it as being connected once this happens. If the computer disconnects and reconnects everything works as expected again, but eventually the same thing will happen again. Sometimes it happens more rapidly and other times it will stay connected for longer. There are 4 other devices on the network and none have experienced this problem (a linux laptop, an android phone, an iphone, and an android projector). My inclination is that it's something with the macbook, but it hasn't had any issues staying connected to other networks. Not sure if it's a feature on the network that is unsupported by this particular computer.
Thanks in advance!
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 4
Guru
Re: Nighthawk RAX120v2 intermittently dropping internet on macbook
What router firmware are you on?
what gateway is it connected to?
Arey ou connected to the 2.4ghz band or 5ghz when it happens?
Message 2 of 4
jasminabasurita
Latest firmware (V1.2.1.22)
Modem: Nighthawk CM2000
I have smart connect enabled on the router, and I've actually been wondering if that's the problem. So the router automatically chooses between 2.4 and 5 GHz
Message 3 of 4
Guru
You could try disabling smart connect and choosing which network to connect to.
that'd let you check stability.
2.4ghz tends to suffer from more interference
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1377 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
