- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk RAX45 Security vulnerability, need ways to revoke OpenVPN client certificate
- Mark as New
- Bookmark
- Subscribe
- Permalink
The VPN service (based on OpenVPN) relies solely on a client certificate and its private key files to be stored on a PC or smartphone for authentication. There is no user ID/password credential checking. If the client certificate and the associated private key files are compromised (for example the laptop is stolen and if its hard drive is not encrypted, the client certificate and key files can be very easily extracted) your internal network can be accessed maliciously via this VPN service. Once you detect your laptop is stolen, there is nothing you can do to revoke the compromised certificate. The only solution is to shut down the VPN service at the expenses of inconvenience to other VPN users whose client certificates are still valid. The other workaround is to use the Access Control to require approval of every new device in the network to mitigate the problem, but it's a huge inconvenience.
In the OpenVPN implementation, there is a way to revoke the compromised client certificate as well as additional module to enforce user ID/password. It's that the implementation on the Netgear Nighthawk does not expose this critical feature.
Has anyone using the VPN service come to the same conclusion? How do I escalate this issue to the product manager?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk RAX45 Security vulnerability, need ways to revoke OpenVPN client certificate
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
