× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Nighthawk RAX50 gaming settings
Bemo
Tutor
I have a Nighthawk AX6, model # RAX50 that I upgraded to for more stable gaming and working from home. Gaming console is an Xbox Series X and modem is an Arris SB8200. I've got 2 main issues going on:
In regards to opening ports, I've tried 2 different ways to open them up so I have an open NAT. One is to manually open all the ports by entering them in and setting a dedicated IP for the xbox. The other is to not specify the ports, but leave the NAT filtering set to Open instead of Secured. Both ways, I still get a moderate NAT type on the xbox in Call of Duty Warzone though the xbox settings will say my NAT is open. Is it possible to have one side Open and the other Moderate?
I'd also like to use IPV6. I set it to auto detect to determine the type needed and the LAN setup is also set to auto configure but the xbox still doesn't register IPV6.
All in all, I'm getting the speeds that I'm supposed to be getting (1000mbps downloaded 35mbps upload), but I'm still experiencing latency spikes all the way to 450+.
The router is updated to current version, ISP came out today to verify all connections are ok, and if I hardwire directly into the modem, everything runs perfectly for the most part. What am I missing in the settings?? I've been at this all day today trying to figure this out. Any help is appreciated.
Message 1 of 3
Re: Nighthawk RAX50 gaming settings
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Message 2 of 3
Bemo
Tutor
Thank you. I will repost there.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1516 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
