×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk RAX50: slow 2.4Ghz for Wifi 6 clients when device plugged into USB port
rhammond84
Follower
Per subject, for any Wifi 6 clients (Samsung Galaxy S20, AX1650 on laptop) at distance from the router (and hence on the 2.4 Ghz band), WiFi speeds are terrible (~5 mbps connection) when HDD plugged into the USB port.  Wifi 5 clients right next to the Wifi 6 clients achieve 60 mbps plus.
Removing the USB devices resolves the issue with all devices connecting at the same approx. speed.  The 5Ghz band seems unaffected.
I can see same issue posted for RAX120 here: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Horrible-2-4GHz-Speed/td-p/1840176.
Is this a fundamental design flaw for the RAX series routers, or is there a resolution?  Tried changing many settings on router, but none have impact (even turning off AX wifi....the Wifi 6 clients still connect at the same v. low speeds vs. Wifi 5 clients on the 2.4Ghz band....so not sure exactly what is going on).
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Nighthawk RAX50: slow 2.4Ghz for Wifi 6 clients when device plugged into USB port
Hello rhammod84,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 685 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
