- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk RAX75 open NAT type multiple xbox's
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just recently purchased the Netgear Nighthawk RAX75 - AX8 8-stream ax5700. I was hoping that I wouldn't have to set this one up for multiple consoles but like every Nighthawk I have delt with in the past, one of my xbox's (2 total) came up with a moderate NAT type in COD Modern Warefare (and Warzone of course). I do have a third xbox but I use it for streaming so I could care less about the NAT type. Unfortunately, I can not get them open. Here are the things I have tried:
1) Port Forwarding.
I tried to forward the COD ports (53,80, 3074,, 53,88,500,3074,3075,3544,4500) to one xbox, but with two xbox's, this didn't work. Not sure if port forwarding even works with two xboxs. I also set up static IP's for each console. and disabled UPNP to ensure the ports didn't change for whatever reason.
(Reset router settings before I tried something new)
2) UPNP
The router comes with UPNP on, so that doesn't work by itself. I also changed the NAT Type in the router to open and still nothing.
I really hoped that UPnP would work, but it doesn't make any difference.
Things I haven't tried:
DMZ server (prefer not to)
Port triggering
Firmware update or change to older firmware.
I am willing to do anything over again or something new to get my NAT type open. Like most people, I don't understand how this is still a problem, especially with Netgear.
Thank you for any advise!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk RAX75 open NAT type multiple xbox's
Hi AKpulse,
If you recently purchased the device, I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/default.aspx
Christian
