- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk RAX80 AX8 Terrible 5 GHz
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just purchased a Netgear Nighthawk AX8 (RAX80), and after an hour, I'm nearly ready to return it.
My previous router was a TP-Link AC1750, and I've also used a Velop Mesh.
For the purposes of my test, I'm using a Intel AX200 wifi card. This is my first experience with 802.11ax (WIFI 6)
I live in a fairly rural area. The nearest houses are at least 200 ft from my access point. 5 GHz is pretty clean.
Immediately after receiving the Nighthawk, I upgraded the firmware to the most recent version.
I tested the 2.4 GHz band, and I got great performance.. around 250-300 Mbps link rate and pings were fast and stable. It worked well with both AX turned on and off.
The 5 GHz band on the other hand is just awful.
AX + 160 MHz -- Never connects or connects but never gets routable internet. Totally unusable
AX + 80 MHz -- Connects but only gets routable internet at a few channels, like 48 or 44. However, ping will fluctate awfully... from 22 to over 3 seconds. Not only that, but the link rate is usually 400-800 Mbps... worse than the AC router it replaced. Lost a bar on the signal strength meter
NO AX + 160 MHz -- connects on channels 48/44 and gets routable internet. Link rate usually 400-800 Mbps. Lost a bar on signal strength. Ping times better but still fluctuate occasionally to 1s or more
NO AX + 160 MHz -- connects and gets routable internet. Link rate usually 400-600 Mbps. Lost a bar on signal strength. Ping times better but still fluctuate occasionally to 1s or more
Ideas? I got this primarily for AX / 160 MHz channels. I can give up one but not both and certainly won't accept worse performance than the old TP Link AC1750.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk RAX80 AX8 Terrible 5 GHz
I must add that I really wish Netgear would restrict the channel options for the 80 and 160 GHz channel widths to only the valid channels. I feel like the current state just results in lots of hunting for good channels. I used this to help guide me, but Netgear doesn't have a channel 50.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have the latest drivers for the AX200? One or two driver versions were kinda terrible leading to disconnects can’t recall which one/ones though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, avtella!
What channel are you using for HT160?
The AX200 driver is 21.20.0.5 which is the latest that the Intel Driver & Support Assistant recommended.
I haven't tried connecting any AC clients yet... if AX/160 doesn't work, there's no point.
My goal is near gigabit wireless speeds using a 2x2 card, and I was expecting better range than the TP Link AC1750.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's curios as to why Netgear wouldn't allow use of channels 50 and 114 considering those are the only channels that offer non overlapping HT160.
