× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk RAX80 Middling WiFi Speeds
comper
I just want to see how others are doing when it comes to WiFi speeds with the AX8. My WiFi coverage is great, but the speed is underwhelming.
I have Xfinity Gigabit coming to my home. I get full 1Gbps to my desktop that is wired in, no issues there. My WiFi speeds aren’t even bad, but they are lower than the modem/router combo I replaced this setup with, which was the docsis 3.1 with the 7800 equivalent, nighthawk x4s I believe.
Anyway, I have done extensive testing with both a Galaxy S10+ as well as an iPhone XS Max. On the S10+, I could never break 450Mbps on speedtests both through ookla (to 4 different servers) and fast.com. On iPhone XS Max, I can’t break 370Mbps.
There are way too many combinations that I tried to list them all. But I am running on the latest firmware for the router. On the S10 I tried both with ax/WiFi 6 enabled and disabled on the router side. I tried every different combination of toggles between beamforming on/off, mu-mimo on/off, ipv6 on/off, 2400 and 4800 mode on 36, 128, and 153 as main 5ghz channel, etc.
When I say every combination, I really mean I’ve spent the past 2 days trying all of them independently and a mixture of on/off, and no matter what, I could never break those speed barriers listed on both phones. Always on the 5ghz channel, and literally from on top of the router to 5 feet away, same results.
Again, I am not saying these are bad results, and I understand the rates listed are theoretical, but the modem/router combo I had before the AX8, I could hit 600Mbps on the S10+ (I don’t have iPhone XS Max tests from that box unfortunately). So I’m not saying it’s unreasonable, and the tests are at least very consistent, but I just want to know if anyone else has eeked out more WiFi speed in the basically ideal conditions that I have tested mine in.
I should also add that any WiFi analyzer only picks up on one neighboring WiFi network, and I tested on several bands anyway, so congestion/interference really isn’t a factor in my house.
I was just super bummed that even with one of/possibly the only WiFi 6 device on the market in the S10, that the speed was literally the exact same as WiFi 5.
Now I’m debating switching back to a stand-alone 7800 or XR500, or possibly that Asus AX11000. Please let me know if you’ve had better luck, and if so, what your exact settings are; but I think I’ve literally tried every combo possible already.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 9
SAM_the_GAM
Luminary
Re: Nighthawk RAX80 Middling WiFi Speeds
On my RAX80 for the 5 ghz band I am using channel 161 and 2400 is the speed I have it set at. If I set it at 4800 I get similar speeds you are receving. I have AX mode turned on. With the speed setting at 2400 on my GIG connection with Spectrum I can get about 667 Mbps down on my iPhone XS Max & iPad and get about 700 Mbps on my Note 9.
Message 2 of 9
comper
Thanks for the response. After trying for half the day again and still not budging over the 370 mark on the iPhone, I decided to just call it quits.
I then saw the RAX120 on sale for $399 on Amazon, so I had my local Best Buy price match that. I've returned the RAX80 for the RAX120 and now I'm hitting 650Mbps consistently on the iPhone and I'm a happy camper.
With so many people recommending the 7800 over the 8000/8000p, or the 9000 if you want to spend more of the "last-gen" stuff, I'm really thinking this is just a Qualcomm vs Broadcom issue and Qualcomm seems to be bringing the good stuff lately, but that's just purely speculation on my end from comparing all these routers lately.
Message 3 of 9
jmleczko
Guide
In the same exact boat here. Xfinity gig. Get near Gig speed on wired. but no matter what I do, I can't get the wifi to go over 450Mbps. I've got a laptop with 802.11ac, so should be well acheivable. Someone from Netgear should pipe up here and let us know what the correct settings are. Looking at just giving this thing back and going the Ubiquiti route.
Message 4 of 9
SAM_the_GAM
Luminary
I changed my settings and now getting more reliable fast speeds on 5G. I downgrade the firmware to 1.0.1.40. Set the 5G speed to 2400 and using DFS channel 108. Not all devices support DFS channels, luckily all my devices support it. Depending on the network card in your laptop determines how fast you can connect. My Dell laptop max is capable of 433 Mbps on AC so the fastest download I receive is 360 Mbps down considering overhead. My iPhone and iPad max is 866 Mbps so the fastest I get down is about 650 Mbps. My Note 9 seems to connect at 1083 Mbps so the max download I receive on it is 700 Mbps.
I am on GIG plan with Spectrum. Over wired I can achieve 940 - 950 down and 35 - 40 up.
Message 5 of 9
jmleczko
Guide
Thanks for the suggestion. Same here, on wired I get pretty close to Gig. I tried downgrading the FW to 1.0.1.40. And using DFS 108. Still can't get past 450. I'm on a MacBook Pro. With 802.11ac. Holding down the Atl-key and clicking on the WiFi icon shows me details of what my device is capable of - 1300Mbps. So feels like it's pointing to settings on the router
Message 6 of 9
SAM_the_GAM
Luminary
None of my Macbooks are AC capable. They are running MAC OS High Sierra. Luckily they support GIG Ethernet. I have found if I try using the Speedtest app in Safari I never get anywhere near 940 down. However, if I use the “SPEEDTEST” app by OKLA from the Mac App Store then speedtests give me 940-950 down. Over wireless the best I can achieve is about 250 - 300 down over Wireless N on my MacBooks.
Message 7 of 9
jmleczko
Guide
if you hold down the Alt key and click on the WiFi icon at the top, what does your wireless adapter show? Mine shows 1300Mbps
On another note, just found out readyshare does not support exFAT. Super bummed about both these issues. For the price of this unit, I'm a bit underwhelmed.
Message 8 of 9
SAM_the_GAM
Luminary
My MacBook Pro shows 300 Mbps on 5 Ghz it is using the Wireless N protocol because it is an older model that lacks the wireless AC so I mainly use it connected via Ethernet.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 6081 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
