× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk RAX80 network problems
codeninja
Follower
I used to own Orbi and just recently upgraded to Nighthawk Router AX8. Since then, I have had problems with network connections.
First, we couldn't use AirPlay any more until turning off AX feature from the Router.
Doing that didn't fix another problem of my HP LaserJet Pro M275 not able to login to WiFi network. I ended up having to plug LAN cable and setup with IP address on PC and MAC, but no Air Print.
The last problem is that Network devices stopped showing up on Macbook Pro. When I goto Network in Macbook, it's empty.
I suspect there is a single root cause that is causing all these issues. I'm still deciding whether to return my router since I can't use AX feature and still have many issues.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Nighthawk RAX80 network problems
Hello codeninja,
If you recently purchased the device, I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/default.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1052 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
