× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk RAXE500
bblaze19
Follower
Nighthawk RAXE500
I am having a issue with losing internet connection. Devices appear to be connected, but when i try to access the internet it gives me page cant be found or TVs lose signal.
My Setup: I have AT&T Fiber with the BGW320 router.  I go through the process of putting it in passthrough mode turn off the WIFI enter the MAC address in the AT&T router for the nighthawk and then connect the RAXE500.
This issue just started on September 8th and doesn't put out internet. It will work after a reboot for 5-25 minutes then everything drops. This router worked flawlessly since March, but now its just a expensive paper weight.
I spent two and a half hours on the phone with Netgear support and they couldn't get it to stay connected either.
ANY SUGGESTIONS?
Message 1 of 3
Guru
Re: Nighthawk RAXE500
Have you tried leaving the bgw in router mode (disable its wifi) and put the raxe's ip address into the bgw's DMZ? or even the RAXE in access point mode?
Sadly, I've seen to frequently the bgw not function properly in passthrough mode.
Message 2 of 3
DarrenM
Sr. NETGEAR Moderator
I have sent you a PM @bblaze19
Thanks
Darren
Message 3 of 3
Discussion stats
  • 2 replies
  • 706 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
