×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk RX80 AirPrint & Airplay Problem
MacinJosh
Hello. My RX80 router appears to continually shutdown Apple related traffic. My printer will not show up in AirPrint and my AirPlay devices won’t show up on the iPhone. A reboot of the router fixes the problem temporarily until the router decides to block the traffic again. It’s super annoying and frustrating and has made my printer (Brother) practically useless. I’ve checked every setting in the app to no avail. Yes, all devices are in the same wifi network.
Any solutions to this?!?! Thanks in advance.
Message 1 of 8
Guru
Re: Nighthawk RX80 AirPrint & Airplay Problem
are you using icloud relay or private mac/ip address? If so, disable those on your home network
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 8
MacinJosh
If I am I don’t know it. Just default settings. Where would I check?
Message 3 of 8
Guru
On your apple devices.
Message 4 of 8
MacinJosh
Then no
Message 5 of 8
Guru
Try it.
Message 6 of 8
MacinJosh
Sorry, try what specifically? Can you elaborate with steps? Thanks.
Message 7 of 8
Guru
https://support.apple.com/en-us/HT211227
https://support.apple.com/guide/iphone/turn-on-icloud-private-relay-iph499d287c2/ios
here's apples articles on the feature. If it shows how to turn them on, turn them off.
Message 8 of 8
Discussion stats
  • 7 replies
  • 779 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
