- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk Rax120 AX6000 plex port forwarding
- Mark as New
- Bookmark
- Subscribe
- Permalink
After installing this router both ny netgear NAS 516 and 316 can no longer send alert messages
or update antivirus i configured this router with the same port forwarding as the old BT homehub 6 but it doesnt send out the email messages the plex server on my 516 also is no longer available even after applying 32400 as a custom TCP please help anyone i have spent 3 hours on the phone to netgear to no avail
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk Rax120 AX6000 plex port forwarding
Reads more like a different issue, unrelated to port forwarding. Have posted how to test the email notifications on ReadyNAS -> https://community.netgear.com/t5/New-ReadyNAS-Users-General/RN104-OS695-unable-to-send-alert-message...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
is your NAT type set to "secure" or "open"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did look at that but when googled it said Open took down all your security leaving everything else computers etc vunerable so didnt try it is that the problem if its secure
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's not true. Secured NAT only modifies a few things and will not expose your computers to the wild Internet. Secured NAT can interfere with things, though. Secured NAT is a "NETGEAR only" thing that advertises to "protect" you more at the expense of blocking too much, like blocking fully ICMPv6 in case of IPv6 (as an example). Same thing for IPv4
Try setting it to open and see if your problem goes away. If it doesn't, we'll look at other things. I have mine set to open since I bought my R7800 (more than a year ago) and have yet to encounter any wrongdoing from the Internet. It interferes with a few services I run, though, when set to secured
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your support will reconnect the Nighthawk and set NAT to open and report back many thanks again
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was on secured have changed to open will go through the NAS devices and the plex outward connection tomorrow
- Mark as New
- Bookmark
- Subscribe
- Permalink
Changed to open still no remote plex and NAS devices still unable to send alert emails or update antivirus which it does on a daily basis
- Mark as New
- Bookmark
- Subscribe
- Permalink
Readynas not sending alerts problem resolved after changing from BT Smart hub to RAX120 had not realised that needed to go itnto Network Settings on Readynas and change the IP address from the old router 192.168.1.254 and the DNS setting beneath to the AXR120 IP of 192.168.1.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Better approach than a static IP config would be using a DHCP client on the ReadyNAS, and create a MAC<->IPv4 reservation so the NAS would get the same address reliably. Funky details like default gateway, DNS servers, would propagate automatically.
The test I've suggested above would have unveiled this issue (DNS, default gateway, ...) in a few seconds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi thank you for your input it would be good if you could give detailed information on how to do that it will benefit myself and others who come looking for the same answer
