× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Nighthawk ax3000
MoseJanitor
Follower
Nighthawk ax3000
Hello, I updated my firmware to the most recent today (V1.0.3.80_1.0.1) and immediately following this update my routers 2.4 & 5ghz bands no longer showed up on any of my devices. I tried the basic turn off/on and factory reset it several times but nothing has solved the issue. All of the routers lights are on and remain on always. Any help is appreciated.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 4
Guru
Re: Nighthawk ax3000
the wifi 2.4ghz/5ghz lights are on?
Just checking to see if the wifi on/off button got hit. You can push and hold it for 2 seconds to turn it on/off.
You've tried a full factory reset? Pushing and holding reset for 7-15 seconds?
If so, I'd actually try reinstalling that same firmware over an ethernet conenction, reset the router, and then try setup again.
If it doesn't work, you could try downgrading to the older version. maybe the one you're on introducted a bug/issue.
Make sure to update/downgrade firmware over a hardwired connection for best results.
Message 2 of 4
detram
I updated my firmware to the most recent yesterday (V1.0.3.80_1.0.1) and my wifi already dropped completely twice in two days. It comes back up after 30 seconds but I can't work like this.
Is there any known issue on the update?
Message 3 of 4
detram
I found many posts complaining about this particular firmaware version.
I downgrade to the previous. Hopefully this helps my issues.
I'll wait few days before confirming.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1368 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
