× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Nighthawk ax4 Chage prior WiFI SSID
ctclone3211
Tutor
Can't get to my WiFi on the new router because the prior router SSID has not been transferred to the new one.  How to get online with the Nighthawk so I can update the new on with the correct SSID and passwords?
Or if I can't get online then how to I make the changes?
Message 1 of 5
Accepted Solutions
Re: Nighthawk ax4 Chage prior WiFI SSID
What modem sits in front of your router.
Message 4 of 5
All Replies
Not sure what that means, but you can change the SSID to your new router to anything you like. You can also use the default (factory) SSID and password on the label on the thing.
It might help if you said what the model number is for your new "AX4" device.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
Read the stiff on how to change the basic wifi settings.
Message 2 of 5
ctclone3211
Tutor
Sorry mis-stated the issue.  Can not get through the setup with the phone app.  Can not get to the web address for the router.  It is 192.168.1.1 but will not register on my desktop.  My laptop attached to the router was able to get there but loss internet connection.  Currently lost as to how to get there.  Have tried Netgear but 1st level did not get the job done.  The router does show on my list of devices attached.
Message 3 of 5
Message 4 of 5
ctclone3211
Tutor
After spending many hours with Netgear, it was determined that I had a defective router and needed to return it from where it was purchased.  Thanks for your responses but this case is closed
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2717 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
