× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk ax4 rax40 setting up issue
Angryasf
Follower
So I've decided to buy a router and check it out and see how well it goes and what a freaking nightmare, downloads night hawk app proceeds through set up goes to login to router using admin and the default password which is password and it keeps saying incorrect password, I did some googling and factory reset the modem, still says incorrect password. The fact I even need to post on this forum about this issue says a lot about the brand. I'm probably that one unlucky guy who brought a botched modem
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
Guru
Re: Nighthawk ax4 rax40 setting up issue
I'm not a fan of the app setup. I usually recommend people use the browser based method. it tends to go smoother easier.
Try factory resetting 1 more time. Push and hold reset for 7-15 seconds while powered on.
Then connect a pc/laptop to the router and attempt using that method of setup.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 554 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
