× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk iOS app issue
Version8
Follower
Set up was seamless, I was able to log into the iOS app, it after restarting the router, it keeps saying make sure my router is in the same WI-FI, which it is, my router is working properly and has multiple devices connected. But can’t connect to the nighthawk app via iOS. Please assist.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
desgrisons
Re: Nighthawk iOS app issue
Had the same issues and had to delete the app, clear all network setting and then I was able to get a persistent signal. The app, in my opionion is not only underwhelming but also not designed for IOS. Thw hub works fine on Mac OS, IOS and windows if you stay away from their apps!!
Message 2 of 2
Discussion stats
  • 1 reply
  • 793 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
