×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
No Internet Connection after Factory Reset
JoeChillers
About a month ago, I bought a router to hook up to my modem. I used the Nighthawk app to help hook up the router and give off internet. The router worked well at the time. Just now I had to reset my internet connection although I accidentally factory reset my router because I held the reset button down for too long. I go to hook up the router again, but this time it says that my connection is secured but with no internet. I go back to the Nighthawk app to set up the router again, but they want me to scan the QR code from when I first bought the router that I no longer have anymore. I choose to set it up manually, but I end up with the same results: Secured, No Internet. I made sure cellular data was turned off when I tried connecting to the internet off my phone and the connection still gave me those exact results.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 10
Accepted Solutions
Guru
Re: No Internet Connection after Factory Reset
try factory resetting both the router and the modem.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 10 of 10
All Replies
Guru
What modem do you have?
You have the rax40?
Message 2 of 10
JoeChillers
Yes, the model is the RAX40
Message 3 of 10
Guru
Message 4 of 10
JoeChillers
ARRIS Touchstone CM8200
Message 5 of 10
Guru
Anything else connected to the cm8200?
it has 2x ethernet ports but you can only connect 1 device to it.
Message 6 of 10
JoeChillers
The only other device connected to my CM8200 is the ethernet cable connected to my computer. Yesterday, I tested the router and made sure that it was the only device connected to the modem to try and get the internet up and running again, but I haven't had any luck with it.
Message 7 of 10
Guru
the CM8200 can only have 1 device connected.
power off the modem and the router, disconnect everything from both, even coax from the modem. Leave it off 3 minutes.
Then connect the coax back to the mode, power it on. wait 3 minutes.
then connect the router to it on port 1 and power the router on.
Don't connect anything else to the cm8200
Message 8 of 10
JoeChillers
After following your instructions, I tried to connect to my network, and it still gave me the same result:
No Internet, secured.
Message 9 of 10
Guru
Message 10 of 10
Discussion stats
  • 9 replies
  • 3213 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
