×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
PPPoE goes off and on RAX40
Ferosuchiki
Hello there. I'm trying to setup my RAX40 with PPPoE. I got a connection like a yo-yo... Im typing this on that connection as we speak, but I must watch the "Internet" light on my RAX40 when I submit this. The light goes on, it goes off, repeat. ALL THE TIME! I bought this router for this very cause! To get rid of the crappy one my ISP provided. Yes I get a stable connection with the original provided from my ISP, but it does not have 5gz wifi and the 2,4ghz is "meh" at best. Latest Firmware (Updated it today), no fix. So basically, it goes on and off all the time. I'm located in Norway, isolated on a island so PPPoE is the way to go. I have a 100/30 line so kinda annoying I cant get it to work >_< Send help!
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
Guru
Re: PPPoE goes off and on RAX40
You would be best served by posting in the RAX forum:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 874 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
