× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Port Forwarding Limitations
EPMeokazi
Follower
To start my router is the Nighthawk Tri-Band AX8 RAX70 (I couldn't find the model in the categories above) firmware version: V1.0.3.92
I'm having some issues with trying to use the port forwarding under the advance options in the router. I'm playing a game that requires a:
TCP: 25,80,110,443,50000-65535
UDP: 50000-65535
however this nighthawk only goes up to 65534 and throws an error if I try to exceed it when i apply the settings. Is there any way to get the nighthawk to use this port?
If thats not possible am I able to extend the DHCP lease to 72 hours instead of 24?
Thanks!
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 1
Discussion stats
  • 0 replies
  • 413 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
