- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Power supplies mized up
- Mark as New
- Bookmark
- Subscribe
- Permalink
In the process of setting up and moving the office around, the power plugs to the Netgear CM1100 modem and Nighthawk RAS49S router got mixed up. Both have same voltage, but the one of the plugs has a centery...one is center pos and the other plug is center neg. If someone has either device, could they tell me what the model numbers are. I called support and it was absolutely useless. Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Look at the back of each unit and there will be imprinted on the unit itself what the center pin is, Will show a symbol and points to the center pin next the the power jack in back.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Power supplies mixed up
After some very close inspection (as with a jeweler's loup) on the plug that I though was center neg, is - center pos; so, both plugs are correct. My error, thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
