Orbi WiFi 7 RBE973
Reply
R6900v2 Ethernet
Greghun
Follower
R6900v2 Ethernet
Changed my SSID/PW on my R6900v2 router but LAN/Internet SSID to my computer will not change to new SSID. My old SSID had an extension (_2EXT and _5EXT) added to it by someone and my kids logged on it with my password. So I changed it. But now, my LAN internet access shows the old SSID and I can't get rid of it. I can disconnect the LAN line from my R6900v2 router and the WIFI picks up my new SSID/PW. How can I get the router to show my new SSID?
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 2
Guru
Re: R6900v2 Ethernet
its a function of windows. And it requires editing the registry and can end up causing bad things to happen if you don't know what you're doing
https://www.howtogeek.com/364291/how-to-change-or-rename-the-active-network-profile-name-in-windows-...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 627 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
