× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX 120 Keeps going offline but wifi still works?
Jaimem91
Tutor
Pretty much the router states its offline and direct ports from router through my pc lose connection and doesnt work. But interestingly while the router says its offline all my wifi device connections are still running through the wifi ok. What the heck is going on its offline but still working for wifi devices but not my pc? Anyone know what could be causing the issue ? I tried swapping ethernet cables from my router to pc through router but the issue still persists from time to time .
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 6
Guru
Re: RAX 120 Keeps going offline but wifi still works?
What actual modem/gateway do you have?
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 6
Jaimem91
Tutor
The modem is NETGEAR - Nighthawk 32 x 8 DOCSIS 3.1 Cable Modem
Model:CM2000-100NAS
I have xfinity internet as well.
Message 3 of 6
Guru
Try this.
1. factory reset the RAX.
2. power off both the RAX and the CM2000
3. disconnect everything from both. even the coax from the cm2000
4. wait 2 minutes.
5. connect coax back to cm2000, and then power it on. wait 2 minutes.
6. Connect lan port on cm2000 to wan port on the RAX. (don't uses the 2.5g port for now)
7. power the rax on and give it 2 minutes. then set it up.
8. try it for a period. Don't use the 2.5g port
Reason I say don't use the 2.5g port right now is I've seen sketchy cables cause intermittent connections between 2.5g ports that work fine on a 1gig port.
If it stays stable then try using the 2.5g port. Just make sure to use a high quality cable.
Message 4 of 6
Jaimem91
Tutor
I'll give it a shot and let you know the results .
Message 5 of 6
Guru
Good luck!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 903 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
