× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
RAX 120 Slow Download speeds
Mandrew373
I have been having an ongoing issue with download speeds on my RAX 120. I factory reset the modem already, firmware is up to date, QOS is turned off. For about a day I got normal download speeds(usually 600-700mbps with my internet provider), and then it throttles down to about 90mbps. If I unplug the modem and router for 5ish mins, then plug them back in(waiting to plug the router in until the modem is fully online), speeds go back to normal for a couple of hours, then go back to 90mbps down. I called my ISP and they see no issues on their side, firmware is up to date on the modem. I tried calling netgear, and because I’ve had my modem for a few years, they refuse to help me unless I pay. Anyone have any ideas?
Message 1 of 26
Accepted Solutions
Mandrew373
Re: RAX 120 Slow Download speeds
Welp, I feel like an idiot now. I replaced the Ethernet cable that ran from the modem to the router and my speeds are running consistently around 660mbps. Been that way for a few hours now.
Message 25 of 26
All Replies
Guru
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How is the RAX connected to the ISP modem? Using the Yellow WAN port or do you have the multi gig port configured to connect to the ISP modem?
What brand and model ethernet device do you have connected?
Same thing happens across other ethernet devices?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Message 2 of 26
Mandrew373
Firmware version is v1.2.9.52
Modem is a netgear cm1000v2
Yes, I am using the yellow WAN port.
The speed issues occur across every device I have connected to WiFi.
I have tested with all those things turned off and the results are the same.
Message 3 of 26
Guru
Same happens for ethernet connected devices?
What channel configurations are currently set on the router?
Is Smart Connect enabled or disabled?
Please detail the current settings seen under Advanced tab/Advanced Settings/Wireless Settings.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
Message 4 of 26
Guru
When your speeds drop, what connection are you showing between the router/modem?
You can find it here:
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
Message 5 of 26
Mandrew373
This is what shows
Message 6 of 26
Guru
What is connected to LAN port 1? Only shows 100Mpbs. 🤔
Message 7 of 26
Guru
And this was while the speeds were low?
Message 8 of 26
Mandrew373
That’s my TV
Message 9 of 26
Mandrew373
Correct
Message 10 of 26
Guru
What devices are you using to speed test with?
Have any that you can test with a ethernet connected PC or laptop?
Message 11 of 26
Mandrew373
Here are the event logs: [admin login] from source 192.168.1.32, Thursday, September 05, 2024 12:54:46
[admin login] from source 192.168.1.32, Thursday, September 05, 2024 12:48:57
[admin login failure] from source 192.168.1.32, Thursday, September 05, 2024 12:48:47
[DHCP IP: 192.168.1.25][Device Name: ] to MAC address b8:8a:ec:7b:72:0e, Thursday, September 05, 2024 12:40:31
[Internet connected] IP address: Thursday, September 05, 2024 12:16:04
[DHCP IP: 192.168.1.24][Device Name: ] to MAC address 70:48:f7:d6:aa:92, Thursday, September 05, 2024 12:11:15
[DHCP IP: 192.168.1.2][Device Name: ] to MAC address cc:98:8b:5b:00:87, Thursday, September 05, 2024 11:48:23
[DHCP IP: 192.168.1.29][Device Name: ] to MAC address 62:ea:ad:61:7f:cd, Thursday, September 05, 2024 11:48:07
[DHCP IP: 192.168.1.23][Device Name: NEST-CAM] to MAC address 20:1f:3b:9a:b8:7c, Thursday, September 05, 2024 11:47:52
[DHCP IP: 192.168.1.2][Device Name: ] to MAC address cc:98:8b:5b:00:87, Thursday, September 05, 2024 11:47:49
[DHCP IP: 192.168.1.22][Device Name: NEST-DOORBELL-BATTERY] to MAC address 24:e5:0f:de:02, Thursday, September 05, 2024 11:47:48
[DHCP IP: 192.168.1.2][Device Name: ] to MAC address cc:98:8b:5b:00:87, Thursday, September 05, 2024 11:46:09
[DHCP IP: 192.168.1.36][Device Name: LGWEBOSTV] to MAC address 4c:bc:e9:2b:f6:ba, Thursday, September 05, 2024 11:45:18
[DHCP IP: 192.168.1.2][Device Name: ] to MAC address cc:98:8b:5b:00:87, Thursday, September 05, 2024 11:45:04
[DHCP IP: 192.168.1.21][Device Name: NEST-CONNECT-8129] to MAC address 18:b4:30:fb:81:29, Thursday, September 05, 2024 11:44:37
[DHCP IP: 192.168.1.19][Device Name: CASSANDRAS-MBP] to MAC address 88:66:5a:0b:1c:31, Thursday, September 05, 2024 11:44:13
[DHCP IP: 192.168.1.18][Device Name: MYQ-E1B] to MAC address 64:52:99:cb:89:be, Thursday, September 05, 2024 11:44:04
[DHCP IP: 192.168.1.2][Device Name: ] to MAC address cc:98:8b:5b:00:87, Thursday, September 05, 2024 11:44:03
[Time synchronized with NTP server] Thursday, September 05, 2024 11:43:38
[DHCP IP: 192.168.1.17][Device Name: ] to MAC address 64:16:66:42:69:78, Thursday, September 05, 2024 11:43:33
[DHCP IP: 192.168.1.15][Device Name: AERAMINI-7821844913F8] to MAC address 78:21:84:49:13, Thursday, September 05, 2024 11:43:22
[DHCP IP: 192.168.1.20][Device Name: LG_SMART_LAUNDRY2_OPEN] to MAC address dc:03:98:ba:3, Thursday, September 05, 2024 11:43:17
[DHCP IP: 192.168.1.16][Device Name: LG_SMART_DRYER2_OPEN] to MAC address 4c:bc:e9:c1:b7:, Thursday, September 05, 2024 11:43:16
[DHCP IP: 192.168.1.14][Device Name: HOME] to MAC address 44:61:32:24:51:50, Thursday, September 05, 2024 11:43:13
[DHCP IP: 192.168.1.40][Device Name: TM21238099] to MAC address 98:43:fa:f6:b1:4d, Thursday, September 05, 2024 11:43:08
[DHCP IP: 192.168.1.13][Device Name: ] to MAC address 64:16:66:81:24:ee, Thursday, September 05, 2024 11:43:03
[DHCP IP: 192.168.1.36][Device Name: LGWEBOSTV] to MAC address 4c:bc:e9:2b:f6:ba, Thursday, September 05, 2024 11:43:00
[DHCP IP: 192.168.1.12][Device Name: AERA-B48A0A8625D0] to MAC address b4:8a:0a:86:25:d0, Thursday, September 05, 2024 11:43:00
[DHCP IP: 192.168.1.10][Device Name: ESPRESSIF] to MAC address 44:67:55:b0:0a:ca, Thursday, September 05, 2024 11:43:00
[DHCP IP: 192.168.1.11][Device Name: AERAMINI-B8D61A10C750] to MAC address b8:d6:1a:10:c7, Thursday, September 05, 2024 11:42:59
[DHCP IP: 192.168.1.8][Device Name: GOOGLE-HOME-MINI] to MAC address d4:f5:47:5b:20:01, Thursday, September 05, 2024 11:42:59
[DHCP IP: 192.168.1.9][Device Name: ADT_S40LR0_01] to MAC address ac:91:9b:54:70:e3, Thursday, September 05, 2024 11:42:58
[DHCP IP: 192.168.1.6][Device Name: ] to MAC address d4:ad:fc:1e:33:a3, Thursday, September 05, 2024 11:42:57
[DHCP IP: 192.168.1.4][Device Name: ] to MAC address 48:e7:da:cd:e0:94, Thursday, September 05, 2024 11:42:56
[DHCP IP: 192.168.1.3][Device Name: GOOGLE-NEST-MINI] to MAC address cc:f4:11:da:33:7d, Thursday, September 05, 2024 11:42:55
[DHCP IP: 192.168.1.5][Device Name: SLEEPTRACKERG2-07-25] to MAC address 54:ef:fe:22:07:2, Thursday, September 05, 2024 11:42:54
[DHCP IP: 192.168.1.2][Device Name: ] to MAC address cc:98:8b:5b:00:87, Thursday, September 05, 2024 11:42:54
[DHCP IP: 192.168.1.7][Device Name: SLEEPTRACKERG2-BA-C6] to MAC address 54:ef:fe:21:ba:c, Thursday, September 05, 2024 11:42:53
[DHCP IP: 192.168.1.32][Device Name: MANDREW] to MAC address 14:f2:87:66:37:4f, Thursday, September 05, 2024 11:42:47
[Internet connected] IP address: XXXXXXX Thursday, September 05, 2024 11:42:30
[Initialized, firmware version: V1.2.9.52] Thursday, September 05, 2024 11:42:28
Cable connection status does not show from my admin page.
Message 12 of 26
Guru
Sorry, I should have been more details, please post cable connections and event logs from the CM modems web page please.
Also please edit out the IP address in your last post here:
[Internet connected] IP address: , Thursday, September 05, 2024 11:42:30
No need to include the WAN IP address for security reasons.
Message 13 of 26
Mandrew373
Tested speed with both my phone and TV. My MacBook does not have an Ethernet port, and my work laptop only works with a VPN enabled, so I don’t think it will give accurate results.
Message 14 of 26
Guru
They have inexpensive USB to ethernet adapters. I have couple I use on my Mac Book Pro
Also since the TV only seems to support 100Mpbs on the connection, it will never see speeds past this.
Message 15 of 26
Mandrew373
Don’t have anything I can connect via Ethernet to the modem unfortunately. My work laptop is the only thing I have that has an Ethernet port, and the block basically all outside websites. There’s only the coax in from Sparklight, and an Ethernet out port. Are we thinking the Ethernet cable is the issue?
Message 16 of 26
Mandrew373
Message 17 of 26
Mandrew373
Message 18 of 26
Mandrew373
Message 19 of 26
Guru
Speed testing with the TV won't give good results as the TV only supports 100Mpbs and won't see past this.
You'll need to get a ethernet connected PC that supports 1000Mpbs to check what your really getting while connected to the router, or you can also directly connect to the CM series modem to check there as well.
I see you have MIMO enabled which is good.
What Basic Wireless Settings are configured on the RAX router?
If you can post the CM modems cable connections and event logs as well here.
Message 20 of 26
Mandrew373
Edited, thank you
Message 21 of 26
Guru
One more WAN IP at the bottom of that post text too.
Message 22 of 26
Mandrew373
Won’t let me edit the post any more :’(
Message 23 of 26
Guru
Will get it fixed for ya. 😉
Message 24 of 26
Mandrew373
Message 25 of 26
Top Contributors
Discussion stats
  • 25 replies
  • 2551 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
