×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RAX 200 NEW FIRMWARE 1.06.78
meinico
Tutor
Good day,
i have the router RAX200 to about 1 year, the cost of the router is more expensive about 500 euro!!!!
I think that the performance the configuration and the speed are very high,
but i think that is impossible that evrithing there is a new release of the new firmware, there are new bug
of the router!!!!!
The new release of the firmware 1.06.078, after complete configuration manually, the router is very fast,
but when change the public IP address (example reboot router) the DNS breaks, and some function stop working.
i am very disappointed for this, and the solution takes a long time!!!!
Good bye
Message 1 of 4
Guru
Re: RAX 200 NEW FIRMWARE 1.06.78
Have you tried enabling IPv6 on the router?
v.78 isn't new and isn't seen on NGs web page. Did you get this from NGs download page:
https://www.netgear.com/support/product/RAX200.aspx#download
or thru the routers web page FW update section?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
meinico
Tutor
Re: RAX 200 NEW FIRMWARE 1.06.138
Thank you for the suggestion, the correct new firmware is 1.06.138.
I do not need the IPV6 connection, becuse i do to enable it?
Where is the function of IPV6?
My configuration is: ONT NOKIA of the internet provider, RJ45 from ONT to ROUTER RAX200 in the wan port(yellow)
internet configuration is PPOE with username and password of the internet provider, after that there are some client
with IP RESERVED ADRESS, wireless configuration, some port forwarding and VPN connection for my smartphone.
With the indicated configuration the router is rock solid with firmware 1.05.132, when i l see the new firmware 1.06.138
on the site netgear, i have downloaded it, i have factory reset to the router, after that i have UPGRADING the router with the new firmware and inserted the configuration indicated above, the router is ok until there is a reboot, in this case stopped some function how VPN.
Because i should activate the IPV6 connection?
Than you
Message 3 of 4
Guru
Under advanced tab/advanced settings/IPv6.
Set it to enable and Auto.
FYI, others have expressed that v.138 FW is causing problems for users on the RAX200. I recommend that you revert back to v.132.
We have notified NG of issues seen on v.138.
@DarrenM
Message 4 of 4
Discussion stats
  • 3 replies
  • 457 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
