× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
RAX120 BETA Firmware
begoldar
Follower
Hi Everyone, I'm looking to get a copy of the BETA firmware discussed on multiple forums to fix my intermittent wifi issues. Thanks!
HARDWARE: RAX120
FIRMWARE: V1.2.8.40
SERIAL: 5VE
Message 1 of 2
Guru
Re: RAX120 BETA Firmware
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
There is no beta FW for v1 RAX120's. Beta mentioned is for only v2's with random reboot issues. Doesn't solve any wifi problems.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 681 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
