Orbi WiFi 7 RBE973
Reply
RAX120 CONCURRENT HT160 AC/AX CONNECTION
mondenath
Prodigy
Does the RAX120 support both ac and ax concurrent on HT160 mhz with max throughput of 1733 and 2400 .
It just need 4 for each client to get max but is that HT160 is support on ac as well and will it be can work concurrently.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 6
Christian_R
NETGEAR Employee Retired
Re: RAX120 CONCURRENT HT160 AC/AX CONNECTION
Hello mondenath,
I'll forward this inquiry to the team and get back to you as soon as I can.
Christian
Message 2 of 6
mondenath
Prodigy
I am waiting to hear back. Low range and high range concurrent access in mixed ax/ac/ mode .
Message 3 of 6
mondenath
Prodigy
ac 160hz.PNGhttps://www.netgear.com/images/datasheet/networking/wifirouter/rax120v2.pdf
As per datasheet what is highlighted yellow condition means . Its not clear.
Message 4 of 6
mondenath
Prodigy
So the internal team is not aware of or still figuring out the answer for simple query
Message 5 of 6
Christian_R
Hello mondenath,
The RAX120 can support 11AC and 11AX HT160 at the same time. When the RAX120 is set to HT160, it will have only 4 streams. If the WiFi client only have one atenna(1x1), the router can support 4 clients HT160 by MU-MIMO. The total throughput can be higher than 1773/2400. However, each client will not be able to get max 1733 or 2400.
Christian
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2144 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
