- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 V2 Constant Random Reboots
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 V2 Constant Random Reboots
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
@Adhit wrote:
Hello been having the same problem. May I have the beta firmware as well please? My first three characters on my router is 6JY.
- Mark as New
- Bookmark
- Subscribe
- Permalink
how can i also get the beta FW? my netgear nighthawk RAX120v2 seems to reboot once or twice a day.
my modem is Nokia BGW32-505
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some troubleshooting would be suggested to see if other factors maybe contributing to your reboots you saw.
How many days of up time did you see before this supposed reboots happened?
@daray wrote:
After beta fw update works seamlessly, but yesterday got 2 reboots after few days, so beta needs further polishing. It’s vast improvement vs .40 but with all fairness it’s still too often when compared to my recent router. BTW I have noticed big discounts for RAX120, so it may suggest the model has some hardware flaws and may be discontinued soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did all devices loose internet access?
What devices do you have connected?
What is happening when this reboot seem to occur?
How is basic and advanced wireless settings configured on the router?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What is the Default DHCP IP address pool range set for?
- Mark as New
- Bookmark
- Subscribe
- Permalink
im an IT network engineer, this wifi router is what is rebooting at least once a day if not 2 or 3 times a day. wired devices and wifi devices are losing connection. the fiber modem/gateway is staying alive during the netgear nighthawk's reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAX120V2
Long story short, I bought a RAX120v2 in June 2022 and the router would randomly shutoff and reboot. I've gone through pretty much all of their troubleshooting bullcrap and it still exists. Netgear seems to have failed to quality check their hardware before releasing it into the market and refuses to own up to it and make things right for customers who spent hundreds on this crap router. Not like it matters to anyone but I'm officially done with NETGEAR and moving on. you'd be angry too if you spent hundreds on a product and it's malfunctioning. Even the support team can't fix this stupid problem but I guess its the customers that screwed up for buying this crap product from NETGEAR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How about lets try loading up a Beta FW that has fixed this issue?
Please post the first 3 characters of the routers serial number seen on the sticker in back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if you want to try the BETA FW that fixes the reboot issue seen on RAX120v2s
Please post the first 3 characters of the routers serial number on the sticker on your unit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
First 3 digits of serial number: 6JY
Firmware version: V1.2.8.40
I am serviced with Comcast/XFINITY
The modem I am using is CM1200 (a NETGEAR modem)
as for LAN cables, I am using CAT6
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes i'd like to try the beta firmware, first 3 letter is 6JY
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sent
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sent.
@greggag wrote:
Hi. I have been dealing with this same issue for almost a year. I would like to try the beta FW. My serial number starts with 6JY. Thank You!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sent.
Good modem too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reporting back that since the factory reset and beta flash to V1.2.8.43-rc my RAX120v2 has been stable without issue. Uptime is 08:14:59:24 per debug.htm
31 attached devices.
This is looking promising, thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The SNR is the first 3 characters?
@Ma3012 wrote:
Hi, I have the router router since 11.2022 and directly run into the reboot trouble FW is updated to the latest regular FW. Reboot occurs minimum note time on day, if there is some higher load on the wireless lan then the reboot can happen 3-4 times In one hour. May I can also try the Beta FW? SNR: 066
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, Thank you.
Sent.
- Mark as New
- Bookmark
- Subscribe
- Permalink
About to reach my self-imposed 30 day uptime milestone on the beta.
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
