×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RAX120 V2 Constant Random Reboots
bachree
Re: RAX120 V2 Constant Random Reboots
I have applied this release candidate firmware 14 days ago and have not had a single restart. I was having 1 random restart a day on average prior to the update. I have followed the specific sequence that was requested.
- Update firmware
- Factory reset
- Fresh setup using hardwired computer through ethernet
- DHCP server IP ranged manual entered as 192.168.1.100 to 200
It is unacceptable to be going through this process for a 400 USD router that we happened to buy 5 of to have all business partners on same kind of equipment. Hopefully, Netgear does not break it again on a future firmware update.
Message 701 of 706
chaosminionx
You literally have v1 users reporting the beta solved their issues with instability and uptime/availability.
The firmware has been issued to v1 users. V1 and v2 have virtually nothing different about them besides a stepping change on the underlying processor.
How were v1 users able to get the RC firmware if it's only for V2?
Message 702 of 706
Guru
Only v2 users had reported seeing this issue. No v1s had been reported since this thread first started.
There was a initial test beta that same out about a year go that didn't work. This 2nd test beta came out last last year.
Why we are checking and conforming router serial numbers. Again, this patch is only for v2 since v1 hadn't been seeing this issue. There would be no need for v1 users.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 703 of 706
OnZoRAW
Could I please get the rc firmware update?
Having random reboots, mostly seems during downloading large files (sometimes multiple times during the same download).
Router: RAX120v2
Serial number: 6K0....
ISP: Ziggo
Modem type: Either a proprietary Arris or Compal
Modem is in bridge mode
Message 704 of 706
Reub4965
Could I please get the beta.
Router: rax120v2
serial: 6JY
Modem: Netgear cm1000
Message 705 of 706
Giggi33
I ask again
My serial starts with 6K0
I have the v2 model ... please send me the firmware update.
Thank you.
Message 706 of 706
Top Contributors
Announcements
Orbi WiFi 6E
