- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 V2 Constant Random Reboots
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120v2 keeps randomly restarting
I will try to put the fan under it, blowing air up, but to be frank I don't expect that to work.
You can see its own fan blowing air down, and if you see pictures of its internals, you can see the CPU is not under the PCB, but on top.
(You can see the pictures here:
https://openwrt.org/inbox/toh/netgear/netgear_rax120_nighthawk_ax12
By the way, potential OpenWRT support is the only reason why I haven't returned this yet.)
Anyway, this is either a bug in firmware that should have been fixed by now, as suggested by the temperature sensor reporting "NaNC", or even worse, it is a hardware design flaw.
I am shopping for an ASUS router myself. Better UI, allows me to disable WPS, and doesn't reboot spontaneously like this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 V2 Constant Random Reboots
Please send me the firmware fix.
RAX 120
Thanks,
Oletome
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have asked over and over again for beta firmware for this device with none being sent and no response from the team. How do I get my grubby little mitts on beta Firmware Version 1.2.3.33!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this still the case? Can you send a screenshot of your uptime?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am leaning towards this being a heat issue as well, but mainly a bad batch. I see I get reboots when I am using the NAS drive heavily. The CPU usage skyrockets and this thing gets HOT to the touch on top. Once I disconnect the drive, and you can feel the router cool down, it becomes stable. I have fans on the way to see if that will help.
Couple of notes, moving the power supply to a different wall socket (even circuit on the house), using many different UPS units including my HT power conditioner, disabling this WMM setting all did not help at all. The fact is, this thing reboots when a heavy load is put on it, and it is hot to the touch (not to burn you, but for electronics, it's most certainly in overheating territory.)
The beta firmware didn't do anything for me, and enabling fan always on didn't help while using my NAS.
After the fans come to test, I'm almost tempted to open this thing up, maybe thermal paste bad from the factory somewhere. Something along those lines
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd get a laptop cooler under ASAP. The longer heat exposure the more damage there will be to the electronics.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I like how the title of this thread says "solved". Absolutely not solved.
I'm actually not sure it's heat related. It doesn't get that much hotter than 75° where my router is, but regardless, it will drop at night when it's cool or during low use periods. I think it's just a defective product that Netgear doesn't want to admit to.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will say at least they are still working on the issue and I feel like they feel it’s solvable. Otherwise there would have been a V3 or they’d stop selling it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This works as well:
Laptop cooler under the router. Been using these since 2012 under ANY router I use.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If someone does have that l, can you also post what your ISP speed is and the physical ports in use.
For me:
ISP 2GB Google Fiber
Multi gig wan port
LAN 1
Currently capturing the debug log in the event of a reboot. Only been up about 13hrs since it reinstalled to capture logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, I am happy to report (so far) that adding the fan/cooler below the laptop has indeed prevented this router from the random reboots (so far.) Of course I will continue to monitor long term and report weekly here if I can.
Please reference my original post for more information on the history, however I'd like to add a few things.
- I have since rebooted many times and the "Always fan option" is NOT on. So the router is doing whatever it wants.
- The fan I am using is the AC Infinity S4 on high, underneath the router directing air flow up. (AKA flowing air from the bottom, and exhausting from the top....think of it like beefing up the stock fan....if that even does anything)
- Previously, it was impossible to copy files to the router NAS drive when a heavy load was put (copying 100gb at once.) The router would get hot. Not burning "OWWW MY HAND HOT", but it makes a person go "Whoa, that is a little toasty, does this thing cool itself?" Now it is cool to the touch, and I can't feel much heat on it at all.
Again - this is seriously to salvage whatever few years I can from this thing. I will report back long term, even though things may "seem" fixed, we need to be sure.
Maybe down the road, I will open this up and see the heatsinks and any thermal paste issues? Not sure? Thoughts on that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anything is possible at this point. Could be that there maybe some missing paste, however if the heat sink IS getting hot as well, I would presume there is paste there and just not enough internal cooling with the fan. Also seems that there is some CPU handling and usage that needs to be tune up in FW to help lower what's going on there as well. Also seems like the safety trigger temp is not activating the fan as well that needs to be fixed.
Glad the fan is helping.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It could be hardware, could be firmware. I'm not sure, but the firmware numbers are the EXACT same on the V1 and V2.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Geez the heatsink is HUGE! I'd be shocked if it's a heat issue unless it's bad thermal paste/pad application.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
